Any damage to stock valvetrain
Old Aug 18, 2005 | 04:40 PM
  #256
boostedwrx's Avatar
over 30k miles with HKS 272/264 and no issues.
Old Feb 15, 2006 | 03:05 AM
  #257
2hot2handle's Avatar
Originally Posted by timzcat
I measured the seal/guide height and it is 24.67mm
Therefore subtract the guide installed height of 19.5 mm and you get 5.18 mm.
This means that 5.18 mm of seal is above the end of the guide.
This means that I am coming up with the same numbers as Revolver.
I am using a digital verneer caliper that I know is not dead accurate but my numbers are almost identical to Revolver's. Thus, the stock springs do not have sufficient clearance, particularly on the 10.8 cam. The 10.2 lift cam is very very close.
David,
I was saying tha the valve stem protrusion in the service manual is differnet as well as the valve lengths. Therefore if you were measuring one valve and Revolver was measuring another then you would get different numbers. Although not the big difference you were seeing.
Edit: I re-read your post and get what you were saying about max lift.
Revolver,
I am going to go back and look at your posted specs on the valves for installed height. The service manual says it is different on the intake and exhaust. Are the spring seats making up the difference so all the valves are the same? Or do the heights need to be shimmed to adjust seat pressure?
On another note, the service manual has the valve diameter as 6.0 mm which freaked me out since the Ferrea valves I have are 6.55 and 6.57. They are also (Ferrea) the same length and stock is different by .02 mm which is only .008 so that can be fixed easily.
whoa.......i just read this entire thread. anyway, so if i got the gist of this. 10.8 lift cams (particular hks 280) will definately have contact. but 10.2 lift (hks 264/272) will be close but not have contact?
Old Feb 15, 2006 | 03:49 AM
  #258
EVO8LTW's Avatar
All HKS intake cams have the same lift and all HKS exhaust cams have the same lift.
Old Feb 15, 2006 | 04:37 AM
  #259
n/m
Old Feb 15, 2006 | 10:40 AM
  #260
TTP Engineering's Avatar
I am with Dave. Was thinking the same thing. I have run 272's and 280's for over a year now, last inspection did not show any wear. Infact just pulled a head from a 272/272 car Sat and there was no damage there either. More wives tales rampant on evom.
To add, we have run the 280's to 8800 or so also according to logs. Yes, on stock springs and no, not on purpose. And no, there is no power on stock turbo in that range.
Originally Posted by davidbuschur
Holy garbage.
There is not interferance issues with the HKS cams! You may (whoever post this on page 1) that there was interferance with the stock retainer on the flow bench but you would have had to open the valve a TON farther than any cam I have seen does.
No fear guys. For those of you that are worried or want to change don't mess with machining the stock retainers. Even if you do it in the car just drop in a set of better springs and titanium retainers.
I have the 272's in my RS right now, completely stock springs, retainers etc. No problems been running the car on the dyno to 7500.
David Buschur
www.buschurracing.com
Old Feb 15, 2006 | 01:15 PM
  #261
nrcooled's Avatar
Originally Posted by Dynofrk666
anyone tested out the GSC cams, i just ordered a set and after reading all this stuff you guys got me worried lol
After purchacing a set of GSC 272s I took them to my engine builder and they mapped out the cams and compared them to the stock valve springs and said yes I could run them but they wouldn't advise it.
At the time their explanation and rationale was over my head but after reading this thread I have a better understanding. I will be running an upgraded spring that can handle the GSCs better then stock.
Old Feb 15, 2006 | 02:49 PM
  #262
timzcat's Avatar
It is very simple. The intake cam at 10.8 lift will cause the retainer bottom to contact the valve seal. It is inevitable, I've done the measurements to back up what Revolver says.
Go back and look and you will see I was originally one of the people that argued that they would not until I had it in front of me and proved myself wrong.
Old Feb 16, 2006 | 10:05 AM
  #263
Zeus's Avatar
I too had to prove it to myself... I am disinterested in participating in any so of debate on the issue. Saw what I saw first hand, and no one will convince me other wise. Granted, I have seen customers car's with HKS cams and what appeared to be no contact. However, there was on my personal Evo.
Everyone knows I support David's knowledge, and generally take his word as Gospel in this application. I just happened to have a different outcome myself with visible light wear rings.
Old Feb 20, 2006 | 07:33 AM
  #264
David Buschur's Avatar
Wow, this thread has come up again
We stock and sell Revolver springs, retainers and cams now. We have been using the springs/retainers on some of our Stage 3 heads (depending on what the car used for we use others too) for about 6 months. Good product.
I still say if you are running 264, 272 or 280 HKS cams you can run them with the stock springs and retainers and never have a single problem from them.
The Revolver cams are freaking amazing by the way. We have installed them in 3 cars now and picked up 40-50 ft lbs in each one of them, over the HKS 280's.
Not for a reflashed car though in my opinion.
David Buschur
Old Feb 20, 2006 | 08:29 AM
  #265
C6C6CH3vo's Avatar
Do you mean, "not for mail-in type of flash - custom tuning is required"?
Old Feb 20, 2006 | 08:33 AM
  #266
Doogie Howser's Avatar
no AEM
Old Feb 20, 2006 | 08:34 AM
  #267
S2Kstephen's Avatar
Wow...another 40-50 MORE than tuned 280's? Details.....
Old Feb 20, 2006 | 08:43 AM
  #268
A custom tune MIGHT be able to get them to idle but it is going to depend a lot on the rest of the combination. I'd suggest some type of speed density system.
Not sure what other details you'd like. The cams kick some serious ***. My RS made an additional 20 whp and 50 ft lbs of torque. Matt's car this weekend picked up 50 ft lbs of torgue over his best ever and that was with a tune that is not exceeding 2.6 volts of knock on the AEM. Our black car made 761 whp this weekend and 531 ft lbs.
David Buschur
Old Feb 21, 2006 | 11:29 AM
  #269
S2Kstephen's Avatar
Hmmm...sounds like I should sell my 280's, and get the Revolver cams along with some springs/retainers!
Old Feb 27, 2006 | 05:25 PM
  #270
Jeff_Jeske's Avatar
For those of you who installed the springs and retainers....did your tapping noise go away?
