Which Test pipe?
Old Jan 17, 2005 | 02:45 PM
SilverStreak's Avatar
I'm running with the Perrin, and would recommend it. It does require the simple installation of a relay to trick the O2 sensor. If I would have known about the UR, I would have gone with that. Why wire another device into your system if you don't have to? The Perrin will fit almost any setup. I don't know about the UR, but that sounds like the way to go! My only question would be whether the UR comes in a 3" diameter or is only offered in a 2.5"?
Old Jan 17, 2005 | 02:55 PM
ThEHiTMaN's Avatar
Just get a test pipe that is 3" and straight..... Then run a Auto zone special O2 sim. Basically it's 2 Anti Foul plugs with 1 of them drilled out. Look in the search and you will find what it is. Very easy works great and dirt cheap. Can't beat that.
Old Jan 17, 2005 | 03:16 PM
DjRiice's Avatar
ok a couple questions, Any one use the UR 3" tp and dp if so any cel light?......i too am going to get the greddy Ti and was wondering are there any full ti dp's and tp's....id like to have a full Ti turbo back 3" system.....?
Old Jan 19, 2005 | 09:00 AM
naucrx's Avatar
Yep, I've got the 3" UR test pipe. It fits up nicely to my 3" downpipe and 3" catback.
Old Jan 19, 2005 | 09:33 AM
hi_nrg_fizzix's Avatar
DjRiice,
Helix makes a Ti test pipe. Haven't seen any Ti DPs yet.
Old Jan 19, 2005 | 09:54 AM
Sweet. In that case, why not go with the UR? It beats doing the extra work of installing the O2 Simulator.
Old Jan 19, 2005 | 10:16 AM
slt's Avatar
slt
The WORKS one is resonated to cut down on all the extra noise that comes with removing your cat. It will through a CEL if you don't do one of the tricks above.
Old Jan 19, 2005 | 05:34 PM
evoego's Avatar
Registered User
I have both the UR test pipe and downpipe and wouldnt trade them for anything. The DP fit well and comes with a flex section.The TP is great quality as well. NO CEL and I have been using them for 20K. I highly recommend these products Go get em' and have no worries. Daryl at UR will take care of you on customer support as well.
Old Jan 19, 2005 | 10:06 PM
2MANYCARS's Avatar
UR 2.5", great stuff.
Old Jan 19, 2005 | 10:13 PM
Evo23IG's Avatar
I have the Perrin Test Pipe, great quality and fitment. Also have the perrin downpipe which is an awesome piece, I also have it jet coating, nice.
Old Jan 19, 2005 | 10:21 PM
jj_008's Avatar
I have a full 3" UR turbo back w/ there high flow cat and I get a CEL all the time .
Old Jan 20, 2005 | 07:00 AM
evoego's Avatar
Registered User
Have you contacted Daryl about this at UR? I am sure he would want to know and would do what it takes to fix the problem. This exhaust ROCKS!! I have the full TB as well.
Old Jan 20, 2005 | 07:13 AM
Z1 Performance's Avatar
jj08 - hav you scanned the ecu to see what code you are getting?
Old Jan 20, 2005 | 08:31 AM
jj_008's Avatar
I get the P0420 cat not working code. Don't get me wrong, I love the exhaust. IMHO, it is one of the best on the market.
I just haven't had time to call Adam@Z1 or Darryl.
Old Jan 20, 2005 | 08:44 AM
hkfeet's Avatar
I got the UR 2.5" tp, looks ugly but doesnt matter. Havent installed it yet, but I might today.
