Apexi Power Intake Kit with Induction Box, got one?
Old Feb 14, 2005 | 10:28 PM
Derek888's Avatar
Originally Posted by wthoevo8
Does anybody have the installation write up or manual in English for this Apex intake and induction box?
I dont know about the box but the intake is in japanese. It may seem complicated but once you start piecing it together its simple. If you dont have the instructions for the intake I can scan a copy for you if you need it.
Old Apr 27, 2005 | 07:40 PM
mooreboost's Avatar
Bump.
Old Apr 27, 2005 | 10:37 PM
AD_LIB's Avatar
i just got this setup, and will install it this week or begining of next. I might take pics and do a writeup on it, it doesnt look terribly hard.
-BA
Old May 1, 2005 | 11:34 PM
rraulston's Avatar
it looks like the Apexi box will work with the Buschur upper intake pipe. Can anyone confirm?? Also ime assuming you use your existing rubber intake pipe and MAF correct??? Thanks.. RRR
Old May 2, 2005 | 11:52 AM
AD_LIB's Avatar
Ok so I installed this sucker on friday night...its a little bit of a ***** to get in, but it works great once you do. I a japaneese girl at my work translate some of the important stuff in the manual to engrish. I will scan it in and do a write up later today. Also RR I have the cusco hard pipe and everything fit fine...so i am assuming that any hard pipe kit would work fine.
-BA
Old May 27, 2005 | 07:29 PM
J8dailo's Avatar
i been running this setup for a while...couldve been happier!... installed to me was actually wasn't difficult, i tried following the directions which i couldnt understand cause it was in japanese... so i did it without the instruction... pretty easy when you know what your doing..
i think the intake might need a retune
Old May 27, 2005 | 08:39 PM
wthoevo8's Avatar
How are you doing on the pic and write up? Thanks in advance...
-BA
Old May 27, 2005 | 10:53 PM
Derek888's Avatar
-BA
I would like to see how yours look with the hard pipe.
Thanks
Old May 27, 2005 | 11:01 PM
Derek888's Avatar
Here is a pic of mine. It just takes some time to figure out where the thing lines up and from there its pretty easy. I would highly recommend looking at my pics so you know where the box lines up and where its suppose to be. There is a gap and its normal but at first I thought it wasnt suppose to have one so thats why I had a tough time in the beginning trying to eliminate the gap.
Old Jun 19, 2005 | 05:40 AM
machron1's Avatar
I still dont' understand...
I still don't understand where it gets air from with that box surrounding it. Stock the air is shoved in via the snorkel, but since that airway is blocked off, where does the air come from now? The hot engine bay?
Old Jun 19, 2005 | 05:54 AM
Derek888's Avatar
only the left side is enclosed...the rest of the box isnt
Old Jun 26, 2005 | 03:47 PM
PapitoEVO8's Avatar
I have the Apexi Power intake but never bought the box. Looks good and from what I heard it actually works. Can say that about too many intake systems. I am running a K&N drop-in right now but I am holding on to the Apexi until I get some engine management.
Old Jul 4, 2005 | 07:56 AM
GDB's Avatar
GDB
So... it's sucking hot air from around the engine bay?
Old Jul 4, 2005 | 08:18 AM
Derek888's Avatar
not really... more like from under the car
Old Jul 5, 2005 | 07:52 PM
GDB's Avatar
GDB
OK thanks.
I just realized that this aluminum box covers the intercooler spray reservoir. Is it easy to remove the cover? Sometimes I need to refill the reservoir quite often.
