evo under construction!!
Old Jan 20, 2005 | 06:21 PM
TeenEVOwner's Avatar
Right now my 2003 Evo is ripped apart inside of a dealership garage awaiting a new transmission...however the clutch has major wear and tear so they are willing to install a clutch of my choosing for absolutely no labor cost...so I have been searching around and the most affordable is the ACT clutch that handles some odd 400ft/lb's...my modifications put me around 300horsepower to the wheels and my goal horsepower is 400horsepower...What I want is a street driveable clutch that can also go to the drag strip and can withstand around 10 launches each time to the drag strip...and also autocrosses
Does anyone have the ACT and how do you like it...or is there something else around the same price but better???
Old Jan 20, 2005 | 06:25 PM
Widebandphillip's Avatar
i got an rps carbon carbon for ya that'll do the trick =) Pm for details.
Old Jan 20, 2005 | 06:27 PM
pyrovice's Avatar
ACT is perfect for your application, streetable and it will last along time. The exedy twin plate for example, don't expect that to last more than a year at most under DD dutys.
Old Jan 20, 2005 | 06:30 PM
EVIL_EVO_VIII's Avatar
What happened to your tranny?My car is at the dealer too waiting to get the tranny or the tc down for howling sounds and gear whining.
Old Jan 20, 2005 | 07:25 PM
plokivos's Avatar
you wont get tranny service on warranty after the dealer install it, that's the only down side.
but ACT's great. it'll take the abuse, as long as you don't drop them. Then go boom.
Old Jan 21, 2005 | 07:37 AM
The gears were grinding in 2nd and 5th the first time around so they replaced the synchros, the gears, front bushings, clutch, flywheel, and pressure plate. After all of that it is still grinding very badly, and when they drained the transmission there were metal shavings in there so they tore it apart and they decided to get a new tranny for it...however they said that my clutch isnt going to last that much longer and they said they would install whatever clutch I wanted for free labor...but they will not be working on my transmission anymore....
Old Jan 21, 2005 | 07:54 AM
oak2207's Avatar
So wouldn't it maybe be wise to go with another stocker one more time just to make sure the new tranny is ok? You don't want to have this one break and then they say "sorry, you installed another clutch." That's probably why they're so willing to do it. Then if that works out, upgrade on the next go 'round maybe?
Old Jan 21, 2005 | 08:26 AM
calhoun's Avatar
listen to him. labour to put another clutch in will be much cheeper then a new tranny if this one goes.
Old Jan 21, 2005 | 08:35 AM
oguratevo's Avatar
I recommend ACT, they are an excellent option for clutches, just be careful on your new tranny, it might end up like your first one doing launches at the dragstrip. Goodluck!
Old Jan 21, 2005 | 08:51 AM
sleet's Avatar
Hmm, this is a good thread for me because I wanna get around upper 300WHP-400WHP. I've got the stock clutch right now but I know it won't hold that.
Old Jan 25, 2005 | 08:02 AM
I went ahead and ordered an ACT clutch and a fidenza flywheel, and it should be installed thursday along with the new transmission....
Also went ahead and got a full turbo back exhaust with the cat delete...
Old Jan 25, 2005 | 08:21 AM
WrX Kila's Avatar
ACT ALL THE WAY. you wont regret it
Old Jan 25, 2005 | 08:27 AM
How has your ACT held up (miles on it...any abuse??)...and does anyone have the fidenza flywheel put on their evo???
