Clutch Adjustment/ Master cylinder info
Old Jan 21, 2005 | 08:15 PM
plokivos's Avatar
http://www.taboospeedshop.com/SCR.htm
Hope this helps to all those with clutch adjustment questions.
Also, it's ACT 2600 (ACT HDSS) specific.
That is all.
Just on the diagram part is great, i don't know about the 1/4 inch rod part.
http://www.automotivearticles.com/Cl...xplained.shtml
other ones...
Old Jan 21, 2005 | 08:43 PM
GOKOU's Avatar
Good info. It looks like the adjustment rod will need to be turn clockwise or lower. I guess the difficult part is how much. Is this trial and error?
Old Jan 21, 2005 | 08:48 PM
plokivos's Avatar
yeh, from what i'm going through, it's a long trial and error.
I've already adjusted 4 times today and it's still not where i want to be.
Old Feb 19, 2005 | 03:13 PM
Deepseadiver's Avatar
I have a question about this. Do you think the locking nut can come loose? Because all of a sudden my clutch enguagment is right off the floor and it is slipping.
Old Feb 19, 2005 | 03:22 PM
alex_alex's Avatar
very interesting. good post !
Old Feb 19, 2005 | 03:47 PM
ACTman's Avatar
That is all.
other ones...
The detail is great and the illustrations are too, but the reasoning is faulty. Any length added to the slave rod will not change the engagement point, but just push fluid back to the reservoir, just like it does when the clutch wears. This is how a hydraulic system self-adjusts. When the pedal is all the way up a port opens up in the master cylinder that allow fluid to flow to and from the reservoir. There is obviously no pressure at that point and the system adjusts the amount of fluid needed to fill the system. By lengthening the rod all you are doing is reducing the amount of fluid needed. Adding length to the master cylinder rod on the other hand will change the engagement point because it reduces the amount of freeplay before moving the m/c piston and pumping fluid to the slave.
Old Feb 19, 2005 | 04:23 PM
WildRice's Avatar
My ACT works to perfection. I did not make any adjustments, the specs for the free play at pedal is in the owners manual. It is a shame that some companys take advantage of the uninformed in such a shamless way. Dirk you were overly kind in your comments. Plok you misght get with Act about your difficulties before you ruin your nice new clutch with some of this nonsense.
Justin at STM
Oct 5, 2012 08:59 AM
jerdeitzel
Jun 1, 2011 08:16 PM
DrivelineSales
Evo 'For Sale' Suspension / Brakes / Handling
58
Nov 24, 2008 12:30 PM
Fizz Autosports
18
Jan 26, 2008 08:13 AM
eazyevo
Southeast Region
Jun 3, 2004 07:13 AM
