did Greddy fix the type S boost contoller yet?
Old Jan 23, 2005 | 08:33 AM
Derek888's Avatar
I heard that the Greddy type S boost controller was having trouble holding boost with the Evo. Do you know if there is a fix to it or how you can make it work properly? I looks very simple to use
Old Jan 23, 2005 | 08:37 AM
Homegrown_Evo's Avatar
Are you talking about a Greddy Type S BOV? I have never heard of a type S boost controller...
Old Jan 23, 2005 | 01:01 PM
umiami80's Avatar
Mine worsk fine. I DID however remove one of the 2 springs in it to make it actually work BETTER then stock. Meaning it holds 20++++PSI of boost without leaking but actually opens under less vaccume (throttle lift) the teh stcok so I actually have less compressore suge then a Stock Evo, Brilliant.
Old Jan 23, 2005 | 07:55 PM
Derek888's Avatar
What if one day I upgrade the turbo, will it hold more than 24psi with that spring mod? I think people were saying they had problems with it holding more than 21-22 psi
Old Jan 23, 2005 | 08:01 PM
Quickshift's Avatar
Mine is holding fine and I am pumping much more volume through my car than the stock turbo. Ive had it hold up to 25psi but I wasnt trying to go much higher than that. I am sure it can hold. But you will have to leave both springs in to hold boost at those levels.
