hallman boost controller ?
Old Jan 22, 2005 | 05:09 PM
ek9jdmhb's Avatar
does the boost controller com with vacuum lines? And also, Do I have to plug the wastgate actuator or can I leave it alone. Thanks
Old Jan 22, 2005 | 05:36 PM
lacartus's Avatar
Yes, about 5 ft of vac tubing and twist ties. You can't plug the wastegate actuator, that's how you control the boost. The side port (output port) on the Hallman gets connected to the wastegate. Check this link for a good diagram and install steps: https://www.evolutionm.net/forums/sh...allman+install
Old Jan 22, 2005 | 05:56 PM
ek9jdmhb's Avatar
on the diagram, it show the wastegate actuator being capped. My boost controller did not come with vacuum lines and only came with 2 caps.
Old Jan 22, 2005 | 10:18 PM
Jakeg97's Avatar
where did you buy it from ?
it should have come with the hose
plus any extra caps can be bought at a parts store
Old Jan 23, 2005 | 08:33 AM
sleet's Avatar
I ordered one from AL and i'm still waiting for it I hope it comes with all the junk.
Old Jan 23, 2005 | 08:38 AM
mump's Avatar
bought mine from al and it came with the stuff.
Old Jan 23, 2005 | 09:22 AM
lacartus's Avatar
Did you buy it new? Mark takes a lot of care in packaging his boost controllers, including a nice box, tubing, zip ties, detailed instructions, warranty registration, caps, etc. If you bought it from a vendor tell the vendor you need the tubing. Otherwise, just go to an auto parts place and buy some 5/32" fuel/vacuum line (black rubber and should have at least one strand of nylon reinforcement in it).
I have the Hallman instructions in front of me and I can't see it telling you to cap the wastegate actuator anywhere...which makes sense, since the boost controller wouldn't work if you did that. I know this install can be intimidating if you don't know how the boost controller works, so take a little time and read that link above; it explains how the controller should be installed, including a nice diagram. The only thing you have to cap is the barb on the turbo inlet pipe. To keep dirt out of the boost control solenoid, either zip it in a baggie or put two caps on the inlet and outlet barbs (get the extra cap at the auto parts store).
Old Jan 23, 2005 | 09:40 AM
sleet's Avatar
How long did it take you to get yours? It's been like a week or more now..
Old Jan 23, 2005 | 10:52 AM
Jakeg97's Avatar
i hope you guys return to al and buy from www.boostcontroller.com
my opinion - that is the fastest service to buy parts from!
how long have you been waiting for al to send it?
boostcontroller sends it same day you order and arrives 2-3 days later - very quick!!
Old Jan 23, 2005 | 10:54 AM
Jakeg97's Avatar
you need to order it from www.boostcontroller.com you will not be sorry with the service or the packaging
Old Jan 23, 2005 | 11:10 AM
ek9jdmhb's Avatar
I ordered mine from dynoflash. It took about a week to get in. I have everything working, now I cant fugure why my car holds 20 perfectly in 4th and 5th, but only goes to 19 then tapers to 17 in 3rd? can anyone help
Old Jan 23, 2005 | 12:52 PM
mump's Avatar
i ordered mine from him on a monday and got it friday, and i live in the middle of no where of this worthless state.
Old Jan 23, 2005 | 05:42 PM
Jakeg97's Avatar
which way did you install it ? turbo compressor or bov line?
Old Jan 23, 2005 | 07:17 PM
sleet's Avatar
Tap into the BOV line.
Old Jan 23, 2005 | 08:10 PM
ek9jdmhb's Avatar
bov line.
