New Clutch, weird
Old Jan 27, 2005 | 01:40 PM
naucrx's Avatar
New Clutch, weird
I just got a RRE No-Name clutch put in my car. I expected a heavier pedal, but the disc does not slip at all. Is this normal? It's nice to have the grip with the new clutch, but getting started in 1st gear may eventually rattle all the teeth out of my skull or shake my car to pieces.
Old Jan 28, 2005 | 09:03 AM
naucrx's Avatar
Bump. No one?
I know there's more people with the No-name clutch out there.
Old Jan 28, 2005 | 09:14 AM
rcheung's Avatar
Is it a puck clutch or a street disc? If its a puck clutch thats normal. They grab like nobodys buisiness. My buddy has a three puck clutch in his 240sx. Every time he wants to get rolling from a stop he has to give it a few hard revs while slowly letting go of the clutch, otherwise the car will either stall or it will buck like crazy.
Old Jan 28, 2005 | 12:22 PM
naucrx's Avatar
It's the street disc that game with the RRE No Name clutch.
The one on the left-->
I didn't expect it to be this grabby. I even stuck with the heavier stock flywheel to try to stay as close to stock as possible.
Old Jan 28, 2005 | 12:26 PM
wingless's Avatar
Dude I just read a thread today about your very issue.... Search no name clutch, RRE stepped in and said there was some simple mech. adjustment. Sorry to lazy to search and attatch.
Old Jan 28, 2005 | 12:30 PM
naucrx's Avatar
Yeah, I saw that today also.
I'm wondering what exactly the adjustment entails. I e-mailed Mike @ Road Race. Hopefully he will be able to offer some specific feedback to help alleviate my issues.
Old Jan 28, 2005 | 12:53 PM
marksae's Avatar
It sounds like your clutch needs adjusting. You're going to need to crawl under the dash and find the rod that goes into your clutch master cylinder. It should be closest to the fender. You can move your clutch pedal to see which rod is moving. That'll be the one you need to adjust.
This page tells you how to adjust the pedal for a DSM. The same concepts can be applied towards the EVO. Good luck.
http://mywebpages.comcast.net/njdsm2/clutch.html
Old Jan 28, 2005 | 02:03 PM
naucrx's Avatar
Nice, thanks for the info. I remember having this done on my 2G GST after a new clutch. I wish I had known how to do it myself before.
Old Jan 28, 2005 | 02:09 PM
marksae's Avatar
After you own a few mitsubishi's, you'll get real good at doing clutch adjustments. hehe.. They all need to be tweaked to shift better.
Old Jan 28, 2005 | 04:26 PM
oak2207's Avatar
Dang that's good info. Thanks! Does this have to be done if you replace everything stock-like?
Old Jan 29, 2005 | 04:47 AM
turboex's Avatar
Mine had to be done right of the show room floor, due to hard shifting. So man did the adjustment fix your RRE clutch? Post up a review for us, im about to order the same clutch
Old Jan 29, 2005 | 07:11 AM
11secEVO7's Avatar
same problem with my act 6 puck.....
it shakes the whole car
Old Jan 30, 2005 | 08:49 PM
naucrx's Avatar
I haven't gotten the clutch adjusted yet, but it is behaving a lot better after 300 miles. I have to get my oil changed soon and an alignment, so I will probably just have the dealership look at the clutch settings also.
