Dissapointed at the dyno
Old Feb 2, 2005 | 02:32 PM
evoracer32's Avatar
i went to get my car dynoed at xs-engineering and it put down 290whp at 6497 rpms, i have the boos set to 1.44 bar and it drops to 1.22 by redline, any ideas of wut might be wrong i figured i should atleast hit 300 hp, from wut i herd most every stock car dynos around 250ish their so that would only be a 40 hp increase, any advice would be helpful
steveevo8's Avatar
What mods do you have??
Old Feb 2, 2005 | 02:33 PM
bigyellowevo's Avatar
What are your mods?
Old Feb 2, 2005 | 03:18 PM
DynoFlash's Avatar
91 octane fuel is a pain
Old Feb 2, 2005 | 03:24 PM
ArchieBabes's Avatar
Yeah I know, I have Stage 4 parts and only dyno 320whp on 91 Octane and that was a mild tune 10:2 A/F Ratio due to the bad gas
Old Feb 2, 2005 | 04:27 PM
evoracer32's Avatar
srry i forgot to add my mods lol, i have a full buschur stage 2 with the flash for 91oc
Old Feb 2, 2005 | 04:33 PM
eve-slow's Avatar
What dyno does XS have?
Old Feb 2, 2005 | 04:41 PM
evo81's Avatar
thats not bad at all for 91 oct with them mods
Old Feb 2, 2005 | 05:15 PM
IE Evo's Avatar
Your expectations are higher than the gas octane. Realize pump gas in the East is halfway to race gas in the West. 10-20 whp on average.
Old Feb 2, 2005 | 08:18 PM
05-EVO-GSR's Avatar
Screw the peak number. What does the area under the curve look like?
Old Feb 2, 2005 | 08:23 PM
Cash Money's Avatar
XS' dyno is a 4wd if i remember correctly... lot's of dyno numbers you see are fwd only converted... 4wd dyno aren't very common...
Old Feb 2, 2005 | 09:46 PM
evoracer32's Avatar
yea that is true that most dynos are not 4wd, im still concerned how even with a manual boost controller the boost is still falling off 3 psi by 6000 rpms
Old Feb 2, 2005 | 10:27 PM
Kaane's Avatar
mine falls off as well, it's just the way it goes. Getting close to 300whp on 91 octane is hard as is. I made only 309 on 91 with many more mods. So what you are seeing is normal. Put some 100 octane and I guarantee you will see extra 20whp.
Old Feb 2, 2005 | 11:15 PM
IE Evo's Avatar
Sounds like a Works disciple. That kool aid be good.
Old Feb 3, 2005 | 08:37 AM
eve-slow's Avatar
The reason I asked what dyno is because different dynos (all 4wd considered) put down different numbers with a big margin of difference.
