Stock boost solenoid help
Hi Guys,
I am in the process of taking off my manual boost controller and hooking back up all the stock boost control tubing. Now I can't remember the proper orientation of this tubing.
It has a T-fitting, with two short pieces of hose (one w/red tape on the end) and one longer piece of tubing. Where do each of these hook up???
I figure the longer piece hooks up to the boost control solenoid (under the air filter?) and goes in one of the straight-through ends of the T-fitting. Where I am stuck is the two short pieces - which goes onto the wastegate and which goes to the turbo? Also, which goes onto which nipple of the T-fitting.
Thanks for any help you can give!!
EVOlutionary
EVOlutionary
Check out plokivos's how-to for a mbc install. It has some great diagrams that should help you go back to stock. https://www.evolutionm.net/forums/sh...d.php?t=114794
EatSleepBoost
Mar 10, 2009 05:07 PM
tokeone
Jan 9, 2006 06:30 AM
SzuChenEvo
15
Dec 20, 2003 02:19 PM
