"How To Lie With a Dyno"
Old Feb 8, 2005 | 01:02 AM
ERGO EVO's Avatar
Thought Dave Coleman's old piece might be a worthwhile read for many...
http://www.sportcompactcarweb.com/ed..._technobabble/
Old Feb 8, 2005 | 01:11 AM
ERGO EVO's Avatar
Sooooo, anyone dynoed their Evo in 3rd AND 4th gear and compared results???
Old Feb 8, 2005 | 06:58 AM
Stinkapuss's Avatar
I did back in 2003. HP numbers were the same but the a/f ratio was a lot richer in 4th then 3rd.
Old Feb 8, 2005 | 08:32 AM
ERGO EVO's Avatar
Hmmmm, and torque??
Old Feb 8, 2005 | 08:36 AM
Stinkapuss's Avatar
Hmmmm, and torque??
Same. The lines were right on top of each other.
Old Feb 8, 2005 | 08:41 AM
ERGO EVO's Avatar
Interesting. Would love to hear some others' experiences. My hunch is that in some instances 4th gear would net more power shown.
Old Feb 8, 2005 | 08:52 AM
Willie Dynamite's Avatar
Opposite, third grear 248hp and fourth gear 230hp.
Old Feb 8, 2005 | 09:21 AM
ERGO EVO's Avatar
Wow...could that be due to heatsoak? Did you do the fourth gear runs before or after the third gear ones?
Old Feb 8, 2005 | 09:35 AM
Fourth gear was first then one heat soaked third gear pull followed by a cool down and then two third gear pulls that were identical(248hp) to within a tenth of a point.
Old Feb 8, 2005 | 09:36 AM
GTKage's Avatar
from my experience nomatter what gear u do your pull u will get the same numbers, the curve will look like a lil bit different that s all. At least this is true with dyno dynamics dyno.
Old Feb 8, 2005 | 09:41 AM
ERGO EVO's Avatar
Were your numbers corrected or uncorrected? Just curious.
Old Feb 8, 2005 | 10:03 AM
I can view them corrected or uncorrected with Dynojet's runviewer.
corrected:231.20hp in fourth and 247.67hp in third.
uncorrected: 237.87hp in fourth and 253.18hp in third.
Old Feb 8, 2005 | 10:06 AM
ERGO EVO's Avatar
Any mods at all? This is an '04 car, yes?
Old Feb 8, 2005 | 11:46 AM
'04 and stock.
Old Feb 8, 2005 | 12:31 PM
David Buschur's Avatar
I dyno in 3rd gear in the EVO's. It does make a difference in power/torque and spool up for sure. The pulls are over quicker, that's the biggest reason I do them in 3rd. It just takes less time and is less abusive on the car. With 335 dyno pulls on the RS I am doing all I can to keep from doing a rebuild before I hit 3,000 miles! haha
David Buschur
www.buschurracing.com
