need help!!
Old Feb 12, 2005 | 02:34 PM
dave9172's Avatar
need help!!
these are a list of my current mods:
-apexi gt spec exhaust
-turboxs boost controller
-hks racing suction intake
-blitz bov
-apexi s-afc-2
-blitz dtt
i have about 2000 to spend im trying to get some more hp, im definately getting a helix dp and test pipe, what else should i get??
273 whp/262 lbs trq
Old Feb 12, 2005 | 03:00 PM
hawaiievo's Avatar
hks cams $600 new fmic and piping. or buschur stage 3. and upper ic pipe
Old Feb 12, 2005 | 10:51 PM
eve-slow's Avatar
water injection w/dynoflash, buschur 20g, and injectors so you can raise the boost.
Old Feb 13, 2005 | 05:24 AM
Dr. Fob's Avatar
Cam, cam gears, fuel pump.
By the way, you may consider RS-R downpipe. It's a long pipe tha includes the test pipe. It clears the front tie bars and fits really well. Much cheaper than buying two separate pieces also.
Old Feb 13, 2005 | 08:10 AM
EVOTEXAS's Avatar
You don't need an intercooler until you upgrade your turbo. I would get cams and a TME turbo and a TurboTrix flash. You also don't need water or alcohol injection.
Old Feb 13, 2005 | 09:06 AM
GreedMOTO's Avatar
walbro fuel pump...its cheap and gives you an added level of safety
a ground wire kit is pretty cheap too...it prolly won't make any power, but it does help idle
Old Feb 13, 2005 | 06:53 PM
dave9172's Avatar
thanks everyone for there input, i think im going to go w/ the dp and test, some kind of ecu flash, and probably a decent set of gauges.
th3whitestar
Jan 17, 2011 08:14 AM
evo9801
Mar 27, 2009 05:24 AM
RuckerPark
Aug 14, 2008 06:28 PM
mattfl
Feb 27, 2005 07:28 PM
mugen5555
Jul 28, 2004 11:14 AM
