19-20 psi on MBC safe with no tune?
Old Feb 14, 2005 | 03:28 PM
DC2Dorifto's Avatar
I am installing my Hallman MBC this weekend. And if it holds said boost until redline, would it be safe to have it do so before getting the car tuned?
Thanks
Old Feb 14, 2005 | 04:21 PM
GBEvo's Avatar
Should be fine althoug you might hit boost cut. I hit boost cut in 4th and 5th gear with it set to 20psi. The only thing that will take care of that is a flash or a tune.
Old Feb 14, 2005 | 04:45 PM
Turbo13's Avatar
yeah mines set at 21, but i got the fuel pump, and dynoflash. it's worth the $200 though to get rid of boost cut.
Old Feb 14, 2005 | 04:46 PM
Kwman's Avatar
I've got to get a damn fuel pump and a tune im set at 20 psi and hitting boost cut is about the scariest thing ever. Next to having sex with a bear...that was pretty crazy.
Old Feb 14, 2005 | 05:33 PM
Evo348's Avatar
mine is set at 20psi to redline with a hallman MBc and ive never hit boost cut nor fuel cut. No tune whatsoever and running on 93oct.
Old Feb 14, 2005 | 05:34 PM
Kwman's Avatar
^Oh yeah....well...did you have sex with a bear?
Old Feb 14, 2005 | 06:00 PM
DC2Dorifto's Avatar
I'm running 93 oct as well. Thanks for the replies, I have the fuel pump... and geting Dynoflashed in March but I don't want to install the pump before that lol 10mpg.
Old Feb 14, 2005 | 06:01 PM
sleet's Avatar
You should be fine, the car runs quiet rich from the factory so you shouldn't have any problems.
Old Feb 14, 2005 | 06:02 PM
PoorBoys's Avatar
I am running 22 pounds with 96 octane and a Dynoflash. It never cuts out on me.
Old Feb 14, 2005 | 06:10 PM
mifesto's Avatar
i would not go above 19 psi with 93 octane.... u WILL go lean on the top end even if people insist its rich, thats on the bottom end......and if its a cold day you will spike....
Old Feb 14, 2005 | 08:55 PM
Evo348's Avatar
Sex with a bear? WTFFFF??? naw man im not down with zoofilia.
Old Feb 14, 2005 | 08:57 PM
inline4g63's Avatar
what does boost cut feel like??
PoorBoys's Avatar
Good call...
Old Feb 14, 2005 | 10:16 PM
Titleist71's Avatar
sorta like hitting a brick wall..I felt it in a 05 STi
Old Feb 15, 2005 | 09:30 AM
DC2Dorifto's Avatar
20psi is too much on 93oct? How about after a tune with the Walbro installed?
