EBAY stuff
Old Feb 16, 2005 | 07:19 PM
propellerhead's Avatar
I'll stick with this one instead:
Old Feb 16, 2005 | 10:43 PM
2k4EvoVIII's Avatar
Originally Posted by bonestockevo8
Two of your friends and yourself= 3 success stories; vs. 1,000,000 crappy cracked even broken straight in half horror stories. Perhaps the evo manifolds are from a completely different source, (which I highly doubt) but even recently their honda manifolds have been cracking.
Read the threads buddy. Many people have tried to make this thing crack with no success. But hey whatever you do what you want.
Chris
Old Feb 16, 2005 | 10:45 PM
2k4EvoVIII's Avatar
Originally Posted by fstgvr4
What anti-lag "support" are you talking about? Is it an additional injector, similar to rally cars?
The evo's in Japan and Europe come with a stock anti-lag setup. No injectors just 2 hard pipes that seem to run from the exhaust manifold back into the engine ( i think one goes to the intake). Anyway its not a Rally Anti lag but it is a anti lag either way.
Chris
Old Feb 16, 2005 | 10:52 PM
johnnysixer's Avatar
Can "Anti-lag" easily be setup on a US spec Evo? Or will you have idle or other driveability problems?
Old Feb 16, 2005 | 10:58 PM
TomeiEvo's Avatar
Actually, of all things it is not an anti lag system unfortunately... On a street car it is only an EGR ( exhaust gas recirculation) for cleaner emmisions purposes.. THe valve on idle gets vacuum and allows some of the exhaust gas to be drawn back into the upper intercooler pipe.. On boost the valve shuts so none of the gas is drawn in... However, according to Ralliart in conjunction with a Ralliart Ecu, is able to use that as an anti lag system on rally cars only..
I always thought it was running like an anti lag in these cars but sadly its not.... AM considering removing it due to the heat generated into intake during idling.. Someone correct me if it is cause I'll be glad to know that it is an anti lag system..
Old Feb 17, 2005 | 04:33 AM
Hammerr's Avatar
I installed one of these "cheap" manifolds from ebay and lost boost and power over the stock setup. The tubing they use is smaller cross sectional area than your exhaust port and the collector is huge in comparison and that transition isn't good for flow. The transition of the tubing to the head flange is very small compared to the exhaust port. I spent some time with a die grinder to blend the inlet transition and the heat and vibration from the die grinder cracked one of the tubes. A waste of time and money for me.
Old Feb 17, 2005 | 04:38 PM
yesevo's Avatar
im confused on this manifold!
Old Feb 17, 2005 | 09:48 PM
marksae's Avatar
Don't waste your time and money. Mod cheap, mod twice.
scorke
For Sale - Wheels / Tires
17
Jan 18, 2008 03:53 PM
CityKnight
For Sale - Part Outs
Aug 29, 2006 02:52 PM
KK
Apr 30, 2005 02:07 AM
JaguarS4R
12
Jan 26, 2005 01:42 PM
