Need tach signal wire for JDM Evo 8
Old Feb 19, 2005 | 02:50 PM
DCD's Avatar
DCD
Hi guys, I'm trying to install a shift light on my JDM evo 8, and I don't know which wire is the tach signal from the ECU.
Can someone please help me out?
Cheers
Old Feb 19, 2005 | 04:06 PM
TD05HR's Avatar
http://www.roadraceengineering.com/e...-ecuwiring.htm
Old Feb 20, 2005 | 05:30 PM
DCD's Avatar
DCD
Hey man thanks for the effort but is that for a US Evo?
I need it for a JDM one, the US and JDM ones run different computers.
Old Feb 20, 2005 | 06:48 PM
Crazy4Cars's Avatar
That is the same for your car bro, PIN 58
Old Feb 20, 2005 | 07:18 PM
MalibuJack's Avatar
Yeah, most of the ECU wiring pinouts between the JDM and USDM car is the same.. I think the major difference is the Injector order and the Coil drivers.. the Tach and sensor wiring should be the same...
go to the apexi website and download the installation guide for the s-afc, it has your pinouts on it for the JDM CT9A
Old Feb 21, 2005 | 07:20 PM
DCD's Avatar
DCD
Cool thanks guys! I appreciate the help
Old Nov 6, 2005 | 09:31 AM
emerlin's Avatar
where is the ecu located? sorry for the dumb question =)
Old Nov 6, 2005 | 09:37 AM
wizzo 8's Avatar
Is pin 58 the same tach wire on an 05 evo? What color is the wire? The Ecu is behind the glove box.
Old Nov 7, 2005 | 05:25 AM
wspy's Avatar
Guys,
US Evo 8 and JDM Evo 8 RS use similar ECUs i.e. 4 plugs w/ 2 rows of pins!
JDM Evo 8 GSR/MR uses an ECU with 3 plugs and 3 rows of pins!!!
Had a guy down here who bought an AEM EMS to use in his JDM Evo 8 GSR and found out that it would not fit/ plug in cause the plugs are completely different!!
He is selling the EMS and getting a MOTEC
Old Nov 7, 2005 | 06:11 AM
MalibuJack's Avatar
Thats a good point.. The late JDM Evo8 (Evo 8.5 or the MR) and new Evo9 use the new conectors.. I haven't even seen the new connectors yet.. I suspect it was Mitsubishi's attempt to stop ECU swaps and slow down the Reflash Tuners..
Old Nov 7, 2005 | 03:31 PM
HB4's Avatar
HB4
I saw on LancerRegister that the plug for the JDM Evo 8MR was the same as the 3000gt
Old Nov 7, 2005 | 06:08 PM
wizzo 8's Avatar
Anyone know?
Old Nov 8, 2005 | 05:00 AM
GDB's Avatar
GDB
As someone already pointed out:
JDM Evo 7GSR = JDM Evo 8RS = USDM Evo 8 = 2 row
JDM Evo 8GSR = JDM Evo8MR = 3 row
The JDM Evo8GSR pinout is below. **** CAN ANYONE WITH USDM EVO9 confirm if the pinout below is same as your (i.e. USDM Evo9) pinout?
Old Nov 8, 2005 | 05:13 AM
edwin's Avatar
the rpm one
Old Nov 8, 2005 | 01:32 PM
HB4's Avatar
HB4
Hey GDB, do you have the pinouts for the 3 row JDM Evo 8GSR/MR?
