Running off of front wheels only
Old Feb 20, 2005 | 06:59 PM
EvoJeff's Avatar
Originally Posted by simevo
Get a Honda Civic
Hahahaha. That is really clever, I mean who would have thought to make a honda civic joke! I mean they are FWD and this guy wants to make his car FWD, making your joke HILARIOUS. Idiot.
Old Feb 20, 2005 | 07:09 PM
PHILLY EVO's Avatar
I'm just trying to find out if my front differental is bad I have a loud bang comming from the front driverside wheel when I turn from left to right and cant figure out what is wrong threre is no whinning..... I love driving in all 4 wheels screw front wheel and honda...
Old Feb 20, 2005 | 07:13 PM
GreedMOTO's Avatar
A bad constant velocity (CV) joint makes a bang and repeated thumping if its broken....
Old Feb 20, 2005 | 07:32 PM
PHILLY EVO's Avatar
Checked the axels and are fine no movement in them.....
Old Feb 20, 2005 | 08:16 PM
ebbeast2005's Avatar
my springs pop in the front like in cars with coil overs i just firgured its from the cold weater should i have it checked out?
Old Feb 20, 2005 | 08:23 PM
Speete's Avatar
Old Feb 20, 2005 | 08:33 PM
GTKage's Avatar
Originally Posted by justchil
I think that's only with the MR that has ACD.
not only the MR, all the 2005 evos can do that since they all have ACD.
Old Feb 20, 2005 | 09:36 PM
feriosi'evotwin's Avatar
acd a nice thing to have when doin' sharp turns wish i had one
Old Feb 21, 2005 | 07:28 AM
AUSS1E's Avatar
Check the exhaust midpipe and driveshaft. When you turn right the exhaust shifts to the left towards the driveshaft and they may be banging together. Mine does. Got it rigged up with some wire to hold it away until I can come up with something more permenant.
Old Feb 21, 2005 | 07:40 AM
matt55's Avatar
When my front diff went out the only thing i could see was that drivers iner cv boot came off , which i found out later that a effect of the diff crapping out . When i truned the wheel right or left it made a loud "POP" and moved the sterring wheel . What you should do is put ur car in gear , jack up the front , trun the drive wheels with your hands back and forth . if the diff is bad the other front wheel will not trun or trun and stop and make a griding sound . hopes this helps ,this is how i found out what wrong with my car , btw it ant cheap to fix !
Old Feb 21, 2005 | 11:46 AM
TrinaBabe's Avatar
You damaged your viscous coupling.
Old Feb 21, 2005 | 01:47 PM
hotrod2448's Avatar
Drain the diff. fluids and look for shrapnel.
TSiAWD666
For Sale - Wheels / Tires
Aug 27, 2016 02:18 AM
Roen
Jun 4, 2015 07:07 AM
TxFAkuma
10
Mar 10, 2012 03:30 PM
Neal@tirerack
Feb 9, 2008 07:15 AM
DSMEVOLUTION
30
Jun 10, 2007 06:10 PM
