Dyno'd HKS 264's w/ graph
Old Feb 22, 2005 | 01:41 AM
Corey's Avatar
Originally Posted by BadazzCR
Just thought I would post a graph of a comparison of the hks 264's verse stock cams.
Only thing changed from the two runs was the addition of the cams. NOTHING else, both runs were made the at the same boost level. I was very impressed at the 30 hp and 30 tq gains across the whole rpm range.
I will be dyno testing the HKS 280's that we got in over the weekend tomorrow on our shop evo here as well and post the graph of them too.
Yeah...could you list the mods your running. I've been waiting for a dyno sheet like this to give myself a idea of what my car is making. Was this on 93 octane?
Mods are: HKS rs intake, HKS dp, HKS cat back, HKS 264's, Perrin test pipe, Walbro 255, mbc set at 20-21, and a custom DynoFlash.
Old Feb 22, 2005 | 01:57 AM
IE Evo's Avatar
Good job and thanx for the info. I can't wait to see the 280s.
Old Feb 22, 2005 | 02:03 AM
ez76's Avatar
like others have asked, what is the complete mod list and was there any kind of engine management already on it?
thanks for taking the time to run this test
Old Feb 22, 2005 | 02:51 AM
hawaiievo's Avatar
looks like pretty good gains to me. cant wait to put cams in.
Old Feb 22, 2005 | 03:58 AM
EVO8LTW's Avatar
Originally Posted by umiami80
I like the 272's, I get big power from them plus when you upgrade a turbo, you will not need to get new cams to flow it properly.
Your dyno is impressive, but unless you have another one with stock cams or 264s (on the same car/dyno/level of tune), it doesn't prove anything about the benefit of 272s over 264s. Also, why does your graph say "uncorrected"?
Old Feb 22, 2005 | 06:22 AM
GBEvo's Avatar
Nice results. That's what I've been waiting to see. Any cam gears or tune for the 264's or is this just putting them in and then dyno with no tune?
Old Feb 22, 2005 | 06:28 AM
umiami80's Avatar
If my graph was "Corrected" it would have shown MORE WHP.
Example...
If you dyno a car in Colorado, you will be down about 20% WHP because there is much less air, it's the land of a 13 second Z06. So you would "CORRECT" those numbers to reflect what it would show at optimal temp and at Sea Level. I am at Sea Level, it was warm and humid that day, if I corrected them, it would have increases the WHP showing, I chose not to. All corrected means is that the power levels are then modified to show what would happen if the BEST conditions were present, which they were not. At best it is an educated guess, I just wanted real numbers, which are shown there.
Before the 272 cams, I had a VERY similar power curve to the other one posted here, I believe I made 302WHP. I credit my HKS RS Intake and VERY VERY read (VERY) good tuning. With my 300WHP I ran like a 12.8 (Stock Clutch, mild 1.8 60 Foot) and a more telling trap of 108MPH. As for my new power curve, I am hoping for atleast 114MPH, and the way teh car has been running lately in this cold weather, I bet I can do it.
Old Feb 22, 2005 | 06:59 AM
GIsnickers's Avatar
awesome graphs
Old Feb 22, 2005 | 07:10 AM
BadazzCR's Avatar
Lets see here, first the cams were installed on the factory gears, I have played around with camgears on the hks 264's to gain little or nothing. So I leave them at 0-0. His mods are 3"turbo back exhaust, helix o2 housing, hks rs suction, upper intercooler piping, MR bov, Dynoflash through the mail base flash, Emanage.
Also I tuned this car before the cams were installed with the emanage and then again after the cams were installed which is why the afr looks the same. Boost was set at 21psi for both runs tappering to around 19psi at redline.
I too can not wait to install the 280's in the shop evo and get it on the dyno, graphs of these cams will be posted tomorrow hope fully.
Old Feb 22, 2005 | 07:42 AM
Evo11V's Avatar
Veteran: Army
yeah we need before and after graphs or like he said it means nothing... do you have a before graph before cams?
Old Feb 22, 2005 | 07:47 AM
BadazzCR's Avatar
I posted before and after. Run#8 is with out the cams and Run#13 is with the HKS 264 cams.
Old Feb 22, 2005 | 07:50 AM
Evo11V's Avatar
Veteran: Army
yes you did but the other one who posted the 272's only put the graph with the cams in. No before and after.
I liked you graph, thats what i've been looking for. any comment on how you think the 264/272 combo would perform compared to just a strai 264 combo, as far as power?
Old Feb 22, 2005 | 07:54 AM
BadazzCR's Avatar
Not sure on the 264/272 cams as I have never dyno'd a set back to back from the stock cams. I am installing the 280's now thought and going to be dyno'ing them to see how much is gained over the hks 264's.
Old Feb 22, 2005 | 07:56 AM
Evo11V's Avatar
Veteran: Army
probably be a number inbetween then lol. I would have the dyno graph but i'm installing the hks rs intake also along with it. so i could take off like 10whp and thats probably the gain.
Old Feb 22, 2005 | 08:15 AM
Aby@MIL.SPEC's Avatar
Nice stock vs. 264 cam compare
I am looking forward to see the results of this comparison
BTW, what octane were you using? Sorry if I missed that from an earlier post
