Dyno'd HKS 264's w/ graph
Old Feb 22, 2005 | 08:31 AM
  #31
EvoTio's Avatar
I loved the 264's in my Talon. Great torque! I also passed smog in Califronia. I can't wait to get a set for my Evo.
Old Feb 22, 2005 | 08:38 AM
  #32
SLVRNBLK's Avatar
Veteran: ArmyFCOTM Winner
I have a set of 264's. Waiting to schedule a custom tune before they go in though.
Old Feb 22, 2005 | 09:24 AM
  #33
Ev0 1's Avatar
Sup Doug, Which shop Evo is this?
Ta
Old Feb 22, 2005 | 09:44 AM
  #34
BadazzCR's Avatar
The 264 dyno graph was from a customers car. But the 280's are going in Gio's car, the black evo (368hp pump)
Old Feb 22, 2005 | 09:52 AM
  #35
BSREVOLUTION's Avatar
was the car using a safc or flash?
Old Feb 22, 2005 | 09:54 AM
  #36
Aby@MIL.SPEC's Avatar
What cams are currently in Gio's car? cam gear settings too?
Old Feb 22, 2005 | 09:55 AM
  #37
BadazzCR's Avatar
The car has the HKS 264's with tomei cam gears but the gears are set at 0-0 as this setting made the most power on his car.
Old Feb 22, 2005 | 10:02 AM
  #38
JustDSM's Avatar
Disregarding peak numbers, you've found no gains anywhere in the powerband by adjusting the cam timing on HKS 264's?
Old Feb 22, 2005 | 10:26 AM
  #39
BadazzCR's Avatar
moving the cam gears just moves the peak power up or down, but not it huge amounts. Maybe 5-8hp at the most, on the 264's. I found leaving the 264's at zero has given the flatest and most usable power curve out there. This was only tested on the 264's so the 272 may be different, but when I was running the 272 in my evo I also ran them at zero and loved the power it made. I think that the cam gears make the most noticable power on the stock cams.
Old Feb 22, 2005 | 10:30 AM
  #40
evodave's Avatar
From: driving the 10 second beast in ohio or running lightmods.net
put the 280s in! hehe
Old Feb 22, 2005 | 10:36 AM
  #41
JustDSM's Avatar
Thanks for sharing that Doug.
Old Feb 22, 2005 | 10:42 AM
  #42
BadazzCR's Avatar
The customer has a greddy emanage and a through the mail reflash. We used the emanage to fine tune the afr's only since it wasn't a custom reflash.
Old Feb 22, 2005 | 08:28 PM
  #43
ctx2000's Avatar
DOUGH is the man, he got the MAGIC TOUCH.
Old Feb 23, 2005 | 02:33 AM
  #44
Corey's Avatar
Originally Posted by Evo11V
yeah we need before and after graphs or like he said it means nothing... do you have a before graph before cams?
No...I haven't dynoed my car since there isn't a dyno worth my time and moeny around here. There is a 2wd DynoJet and a AWD Mustang Dyno here, but the Mustang reads really high from what I've seen. To get actualy numbers I'd rather dyno on a DynoJet. I might use the AWD Mustang for the hell of it, but I'm sure it'll be wrong.
Old Feb 23, 2005 | 05:39 AM
  #45
Evo11V's Avatar
Veteran: Army
lets see the 280 charts!!
