anyone boosting 22 psi or higher on stock turbo?
Old Feb 23, 2005 | 12:37 PM
plokivos's Avatar
i do 21 psi for a while, but lowered it to 19.5.
I wish I could set it to 20 psi and peak just a bit at 4000 rpm to 22 psi... damn mbc...
Old Feb 23, 2005 | 01:04 PM
MattGold's Avatar
Originally Posted by EVOTEXAS
why? I don't run any. I have heard of ARPs having bad installs or failing more than stockers having problems. I realize it's a cheap mod, but the install of my stockers was certainly not done wrong....
That's like saying "why wear a seatbelt - I've heard of people drowning because they can't get their seatbelf off."
It's a safetly precaution that has been proven over 10 years of 4G63, MKIV, SR20DET, and B-Series building.
Now, I don't think it's that important to pull the head off *just* to install head studs... but if you're putting in cams, or valvetrain, you're foolish NOT to... IMHO
-Matt
P.S. I have to imagine the amount of ARP failures over the past 10 years in under 1/2%. They're very respectable, and very consistant with their product.
Old Feb 23, 2005 | 02:05 PM
gsujeff55's Avatar
Originally Posted by Evo348
on 93oct, anything beyond 20 would make the sensor to knock therefore pulling timing. Mine peaks at 21 and tapers to 19.5 around 7k. Also to boost more on the safe side i would consider getting bigger injectors and a better fuel rail, at least.
23psi, no timing pulled here.
Old Feb 23, 2005 | 02:14 PM
EVOTEXAS's Avatar
-Matt
1. Drowning is not a fair comparison to justifying not wearing a seatbelt. Injuries or deaths caused by aftermarket seatbelts compared to properly functioning seatbelts would be closer.
2. That is part of my point. If I had the motor apart I would upgrade the hardware. Duh. Part of the problem with putting in ARP stuff is that most people do it improperly. I have even seen ARP rod bolts fail on a friend's car.
Old Feb 23, 2005 | 04:05 PM
vegasboy301's Avatar
Originally Posted by evo81
you can run more psi with an alky kit
Old Feb 23, 2005 | 07:07 PM
Evo348's Avatar
well buddy, looks at your mods. I meant more for a stock-ish evo. You should be doing good specially if you went with vishnu.
Old Feb 23, 2005 | 07:12 PM
electricevo's Avatar
Mines about 22 daily too, i've seen it actually go a little higher than that after highway trips for some odd reason...
Old Feb 24, 2005 | 04:14 PM
ct9a gsr's Avatar
Just curious... why are Bushur Racing's stages 1-3 all set for 19psi, instead of 20, 21, or 22psi? Assuming that you all are right in saying on 93/94 octane, you can boost that high with no problems?
Old Feb 24, 2005 | 04:29 PM
EVOTEXAS's Avatar
Because they tune lean as crap from what I understand.
Old Feb 24, 2005 | 06:09 PM
2MANYCARS's Avatar
21psi tapers down to 19.5 @ redline.
Old Feb 24, 2005 | 06:46 PM
Huscroft6's Avatar
23 PSI in 3rd here on 93 oct, tapers to 21
Old Feb 24, 2005 | 06:47 PM
PoorBoys's Avatar
22 psi daily on 96 octane with a custom Dynoflash. Thing runs better than when it was stock.
Old Feb 24, 2005 | 06:57 PM
rt turbo's Avatar
right now im running 20.5 psi as per dynoflash instructions. i have basically br stage 4 with 272s and the 660s W/ fuel rail. my afr is around 11.5 and no higher. al says not to go higher than 20.5 but i think he may be conservative to reduce engine failures. with my mods can i go higher? i run only 93 octane.
p.s. i love the dyno flash, but on certain nights i wouldnt mind raising boost.
Old Feb 24, 2005 | 07:02 PM
PA-silver03evo's Avatar
Sorry, I am not sure if the original question was refering to stock fuel system or not so I will ask. What is the highest boost the stock fuel system can keep up with? I used to have a heavily modded 1g talon but havent started modding the Evo yet so I am not sure of the limits of the car. Thanks
Old Feb 24, 2005 | 07:03 PM
YellowFever's Avatar
22 psi here on 94 octane
