anyone boosting 22 psi or higher on stock turbo?
Old Feb 23, 2005 | 05:54 AM
Derek888's Avatar
How safe is it to boost 22psi?
Old Feb 23, 2005 | 05:57 AM
93civEJ1's Avatar
I boost 22psi daily on the stock turbo....Peaks at 23psi in 5th.
Cajun Power's Avatar
Same here.
Old Feb 23, 2005 | 06:49 AM
Turbo Meg's Avatar
Same here, I thought my factory boost gauge was off! I hit 22 Psi in all gears but first.
Old Feb 23, 2005 | 07:36 AM
EVOTEXAS's Avatar
21.5 on 93 and 25.5 on VP C16. I wouldn't push more than 22 on pump. It's getting out of the efficiency range and really heating up the air. I also run one step colder plugs.
Old Feb 23, 2005 | 08:02 AM
SubiEvolved's Avatar
Ditto
Old Feb 23, 2005 | 08:13 AM
midwestmonster's Avatar
If you're going to boost any higher, you should consider head studs.
Old Feb 23, 2005 | 08:20 AM
EVOTEXAS's Avatar
why? I don't run any. I have heard of ARPs having bad installs or failing more than stockers having problems. I realize it's a cheap mod, but the install of my stockers was certainly not done wrong....
Old Feb 23, 2005 | 08:23 AM
RobS's Avatar
I run 25 psi on the stock turbo. 94 octane + Buschur alcohol injection kit.
Old Feb 23, 2005 | 08:26 AM
Event-Horizon's Avatar
23.5psi peak to 18~19 taper on 93oct. I have head studs also.
Old Feb 23, 2005 | 09:47 AM
DR_EVIL's Avatar
22psi here daily on 93 octane
Old Feb 23, 2005 | 11:41 AM
evo81's Avatar
you can run more psi with an alky kit
Old Feb 23, 2005 | 11:53 AM
Evo348's Avatar
on 93oct, anything beyond 20 would make the sensor to knock therefore pulling timing. Mine peaks at 21 and tapers to 19.5 around 7k. Also to boost more on the safe side i would consider getting bigger injectors and a better fuel rail, at least.
Old Feb 23, 2005 | 11:54 AM
WannaRace's Avatar
25psi, 100octane, head studs
Old Feb 23, 2005 | 11:55 AM
93civEJ1's Avatar
oh yeah, me too, and fuel pump.
