stock bottom record?
Old Feb 23, 2005 | 01:36 PM
hueman's Avatar
what's the record power output for the 4g63 on stock bottom/stock internals?
Old Feb 23, 2005 | 01:37 PM
evodave's Avatar
From: driving the 10 second beast in ohio or running lightmods.net
i think people have pushed it up to around 560awhp dynojet for short dyno testing
Old Feb 23, 2005 | 01:40 PM
hueman's Avatar
WOW. but would the motor be ok with that much power?
Old Feb 23, 2005 | 01:49 PM
kcevo's Avatar
I recently put down an average of 480whp on a Mustang with a peak of 500. Also, this was on a 92 octane pump gas map that we just put down 410 whp with 22 or so psi. Drained the tank and put 110 and turned the boost up for 2 pulls and got the 480whp average on 26 to 27 pounds of boost. Don't know what it has left in it, but not really wanting to find out, so I am doing some upgrades to the bottom end before it lets go.
Old Feb 23, 2005 | 02:35 PM
evodave's Avatar
what turbo and ems setup are you running?
Old Feb 23, 2005 | 02:38 PM
plokivos's Avatar
i've seen it high as 550whp on stock bottom with upgraded turbo/ FMIC.
but you know, i don't know if you count cams, cause it had cams in it.
Old Feb 23, 2005 | 04:23 PM
BadazzCR's Avatar
I believe Al (dynoflash) has the highest stock bottom record. He did 556 before pulling the motor and building it a year ago.
Old Feb 23, 2005 | 04:28 PM
hueman's Avatar
yeah, i was just wondering what stock rods/pistons/etc could hold. cams are cool
Old Feb 23, 2005 | 04:51 PM
DynoFlash's Avatar
True - and our fearless customer Superz make 535 on his engine and keeps driving it.
Old Feb 23, 2005 | 04:53 PM
evo_whiplash's Avatar
Thats a very strong engine.
Old Feb 23, 2005 | 05:43 PM
superz's Avatar
Sup Al! I will be visiting you soon Actually I traded the blue Evo in a month ago and now have an MR I will soon be re-installing all of my old parts and will get flashed once again- 500+whp here we come . My BBY Evo held up amazingly well even when running 23psi daily (=425whp). I never had any issues mechanically, no headgasket problems, no bottom end problems. There is NOTHING like driving a stock ECU Evo daily, nothing beats the driveabilty.
Old Feb 23, 2005 | 06:12 PM
bigyellowevo's Avatar
Did you have stock rod bolts also?
Old Feb 23, 2005 | 07:01 PM
hueman's Avatar
can you hit 500whp stock rods/pistons on pump?
Old Feb 23, 2005 | 10:51 PM
superz's Avatar
I upgraded the rod bolts and headbolts to ARP hardware. And no, I dont think its possible for anyone to ever hit 500whp on pump.
Old Feb 24, 2005 | 12:21 AM
nickracer9's Avatar
big enough turbo and anything is possible. if you can deal with your power coming on at 7k.
