Question on separating TC from Tranny
Old Feb 25, 2005 | 08:16 AM
MayhemSi's Avatar
Originally Posted by Zeus
Are you just doing a clutch job? If so, don't pull the TC all the way out, just seperate it from the tranny and "let it lay".
Bingo. It won't fall on ya (At least none have fallen on us yet with 4 clutches so far)
Old Feb 25, 2005 | 10:30 AM
RalliArtEvoVIII's Avatar
noo...im changing T/Cs. no clutch involved.
Old Feb 25, 2005 | 07:58 PM
nxs123's Avatar
I haven't personly done this myself, have only done a few clucthes .
Originally Posted by superz
You can remove the t-case without touching the tranny by splitting the tail of the t-case off, this gives you enough room to remove it without ever touching the engine mounts or the subframe.
Old Feb 25, 2005 | 08:05 PM
SuperHatch's Avatar
You need to take the bolts out of the front and rear engine mounts. One is in front below the turbo, the other is in the back on top of the tranny (you can get to it with the battery out from top). Once these mounts are disconnected the motor can rotate fore and aft pretty easily. You will need to jack up the front of the engine under the front motor mount. This will cause the engine to rotate away from the rear crossmember giveing you more room to drop the TC out through. This is the procedure that the Mitsubishi Service manual calls for when removing the TC. You will also need to remove the dust sheild that is on the tailshaft of the TC. It's the round tin piece that frotects the tailshaft/riveshaft interface and seals the dust out. With that dust sheild removed and the motor rotated from jacking it in the front the tC can drop right out. It doesn't seem like these two small things help that much, but believe me, they make a world of a difference.
- Steve
Old Feb 25, 2005 | 09:32 PM
hey i read this late, but yea i did that. removed the front and rear mounts, and jacked the front of the engine up, didnt remove the dust cover off the tail of the TC tho, but yea that thing was in the way and i was thinking of removing it, but just shoved and shaked and the TC fell out, what a relief. putting the TC in didnt take that long. took about 3-4 tries and shoved it right up there. thanks for ur help guys!
