The TRUTH about aftermarket intakes!
Old Jan 16, 2003 | 07:01 PM
purecoda's Avatar
Post The TRUTH about aftermarket intakes!
I'm sure everyone has heard everything they need to know about intakes.
READ THIS ARTICLE
It might change your mind about aftermarket intakes. Just to let you know, its kind of a mix of good and bad news.
Performance Air Filters
Please let me know what you think about this article, and be able to back it up with stats or experience; hear-say means nothing.
D
Old Jan 16, 2003 | 07:17 PM
2002OZ's Avatar
question
Has anyone thought about putting some ducting from the lower bumper to the short ram intake. Would that get colder ait without acctually having a cold air intake like the aem or ingen
Old Jan 16, 2003 | 07:27 PM
purecoda's Avatar
i know weapon r has a ram air kit you can add to almost any intake, and yeah, i think that would lower the inflow temperature.
http://*******************
D
Old Jan 16, 2003 | 07:44 PM
Score's Avatar
Its not that big of a secret that open cone filters arnt good. Cold air induction is always better.
Old Jan 16, 2003 | 08:23 PM
trance's Avatar
well...untill they make a CAI for auto trannys with little restriction in the pipeing i guess i'm stuck haveing to use a short ram with a heat shield
Old Jan 16, 2003 | 08:41 PM
HobieKopek's Avatar
On the butt dyno, the difference between CAI and SRI is not easy to tell.
Old Jan 17, 2003 | 02:32 AM
AndyF_RSX's Avatar
If you can't fit a cold air feed to your open intake filter then you would be better off keeping the standard airbox and fitting a freer flowing filter within this.
On my Evo6 I've fitted a large 3" piece of ducting to feed cold air from a duct on the front bumper up into the engine bay and it finishes right at the inlet of my intake filter.
See picture below with the ducting feeding into the standard airbox
Andy
Old Jan 17, 2003 | 09:52 AM
purecoda's Avatar
here's the pic of the ram air kit from weapon-r.
sorry it took me so long to edit this.
Old Jan 17, 2003 | 10:42 AM
evoque's Avatar
Re: question
hey that's what ive been thinking!!!!
i thought of using AC ducting* of 3" with the built in metal wire coil(to keep it from collapsing) with a reflective outer coating to keep it as cool as possible .
i also figured since the ac ducting was somewhat flexible and not directly connected to the intake therefore NO siphoning effect, keeping it safe from deep water puddles
*the type they use on building air conditioners, comes in a variety of diamters
Old Jan 20, 2003 | 09:52 PM
gvr4v's Avatar
Why do all the US Lancer owner talk about your vehicle in the EVO section??
Old Jan 20, 2003 | 10:22 PM
purecoda's Avatar
Because I'm a GOD DAMN NEWB!
My phat, sorry 'bout that. Never happen again, I swear.
D
Old Jan 20, 2003 | 10:31 PM
jon527's Avatar
Any insights on this? http://*******************/airbox.html
Old Jan 20, 2003 | 10:32 PM
Aznevo7ution's Avatar
Exclamation Answer to your question
Because US Lancers are bone stock EVO's
Old Jan 20, 2003 | 10:51 PM
JeffCS's Avatar
<sarcasm>
has anyone thought about buying an an air compresser normally used to fill tires and mounting it in the engine bay, with a hose going into the intake tube, and a button in the cockpit to turn it on?!!!!?/!?!?!>?! you can run the power plug into the cockpit and use a power inverter to plug it in!!
</sarcasm>
...but would it actually do anything? just wondering..
Old Jan 20, 2003 | 11:06 PM
AiRicLy's Avatar
Originally posted by JeffCS
<sarcasm>
</sarcasm>
thats an interesting idea but i think those air compressors use more energy then a car can supply.
