EVO 8 Transmission rebuild questions
Old Mar 1, 2005 | 09:32 AM
4ringturncoat's Avatar
Never done a dog so I don't know.
Old Mar 1, 2005 | 09:43 AM
SuperHatch's Avatar
Originally Posted by Yaroslav
Is TRE TRANNY close to dog box in shifting?
No, it's a stock box that shifts the way they were designed to, not the way built them. In other words when mass producing parts you can and usually do end up with parts at the limits of their tolerances that still work, so they make it through Q&A (Quality and Acceptability) inspection. However, they will never perform as well as a part that was built at exact (or as close as humanly possible) tolerances. This is essentially what TRE does, they set up the tranny exactly the way it should be, and do some other tweaks that are trade secrets. It is still a fully syncronized gearbox, no dog setup.
- Steve
Old Mar 1, 2005 | 09:57 AM
propellerhead's Avatar
I can't wait to get my rebuilt beeotch installed along with the Quaife LSD.
Old Mar 1, 2005 | 10:08 AM
Yaroslav's Avatar
- Steve
Thanks for clear answer man!
Old Mar 1, 2005 | 10:12 AM
SuperHatch's Avatar
Glad I could help...
Old Mar 4, 2005 | 08:20 AM
Az3ar's Avatar
I have to get this done to my EVO with front LSD. I mean mine shifts fine but I want it to feel like my S2000 when i used to shift at 9K killing gears with no problems. However, I am not sure if I will go with Shepered or TRE.... after all both are amazing.
Old Mar 17, 2005 | 06:56 PM
4G63 T's Avatar
whats TRE web site?
Old Mar 17, 2005 | 07:08 PM
VTECH8TR's Avatar
Its http://www.teamrip.com
Old Feb 9, 2013 | 04:39 PM
bighead87's Avatar
I'm having a problem with my 5speed trans when I drive Normal my 4th goes in normal but when I'm in boost at high rpm It tends to grind a little to go in and also when I down shift it grinds a bit and won't let me go into 4th.... What can that be I'm think it could be my syncros please help
Old Feb 10, 2013 | 12:05 AM
adriano_917's Avatar
Its more than likely the synchro.
Old Feb 10, 2013 | 07:35 AM
gpfury86's Avatar
Depending on how hard it's been ground, when the synchros get worn and u keep shifting hard and feel grinding, it's going to put a lot of wear on the sliders and synchro gear. Synchros aren't the only thing that wears. The hubs can get indented the slider splines and synchro/ synchro gear splines can get rounded making them harder to align with each other. Places like tre and shep most likely always replace the hub and slider if there is any slight signs of wear between each gearset and the synchros on each side of the hub/slider. There's more to a good shifting tranny most of the time than just replacing synchros. I rebuilt my last trans and it shifts great.
Old Feb 10, 2013 | 07:38 AM
oscarquinones's Avatar
tre tranny
Alexmo530
Jun 16, 2017 07:05 PM
Alexmo530
Jun 15, 2017 04:49 AM
Skinchin13
Nov 23, 2013 03:48 PM
bigkeyIX
Jul 19, 2012 01:04 PM
phizzalot
19
Dec 23, 2011 10:57 AM
