Evomoto Cam Install Tutorial?
Old Mar 6, 2005 | 08:33 AM
forum04pl's Avatar
did mine last night and used streetracing.org tutorial as well. took about 3 hours maybe a little more. double and triple checked everything. just make sure you take pictures of everything so you have refrences just in case.
Old Mar 6, 2005 | 08:57 AM
erikgj's Avatar
Not to hijack but all the Evomoto tech articles were good. Sorry to see them go away.
Old Mar 11, 2005 | 05:29 PM
HiHeatEVO's Avatar
i'm nervous about this. anyone set hks gears on stock cams? i'm thinking -4/-4 from what i've read about somebody installing some aem cam gears.
Old Mar 13, 2005 | 09:47 PM
HiHeatEVO's Avatar
bump
what do you torque the adjusting bolts to and the cam bolt itself?
Old Mar 13, 2005 | 10:48 PM
evo81's Avatar
Originally Posted by HiHeatEVO
bump
edit:wrong bolts sorry
Old Mar 14, 2005 | 03:36 AM
EVO8LTW's Avatar
Originally Posted by evo81
as tight as you can
What?!? No where NEAR that tight. The cam gear adjustment bolts on the AEM gears shold be 15 ft-lbs...which is not tight at all. If you're worried use loctite. They should be progressively tightened in a star pattern. Remember, these are lightweight aluminum gears.
I don't have the spec for the cam bolts handy, but it's in the neighborhood of 45-65. Make sure you find out the exact torque before you start and use a torque wrench.
In my book "as tight as you can" is about 140 ft-lbs!
Old Mar 14, 2005 | 06:47 AM
Zeus's Avatar
About 15 ft lbs on the cam caps...
About 65 ft lbs on the one center cam gear bolt...
...per Mitsubishi.
Old Mar 14, 2005 | 06:51 AM
sr20det91's Avatar
Whats your e-mail??
I have to evomoto cam install in pdf. file.
I can send it if you like.
Old Mar 14, 2005 | 06:57 AM
b18flip's Avatar
Originally Posted by ghettogreg
Hey guys, I've got that EVOMoto cam install guide saved on my computer in pdf format if anyone wants it. Just pm me or post your email and I'll get it to ya asap. It's a good write up, so I'd be glad to pass it along to anyone that needs it.
Let me know,
g
Rpsvelasco@gmail.com thanks greg
Old Mar 14, 2005 | 07:03 AM
Kwman's Avatar
kw63386@appstate.edu PLEEEEEAAASSSEEE
Old Mar 14, 2005 | 07:13 AM
FuelsResearch's Avatar
This method of cam repacement makes me nervous, I know many do it but I wonder how many of the bigs shops do it this way. Is the oil pump driven of the timing belt in the evo? How are the balance shafts positioned? Are they on the timing belt or do they have there own belt? What about the tensioner, some cars need a new one anytime tension is relieved. I'm sure it is a pain to remove all accesories to remove the whole timing cover, but the consequences of skipping a tooth or having a belt misaligned on a pulley seems too grave. I'm new to the 4g63, so I would like to see a diagram (hint,hint). On other cars I always remove the front cover. Can some of the more experienced chime in on this. Thanks.
Old Mar 14, 2005 | 08:53 AM
sr20det91's Avatar
^^^^^People use that method everyday with no problems.Including the big shops.
Though it is a good idea to do the belts as well depending on the mileage.
The main concern is the independent balance shaft belt. If it breaks and gets tangled up in the timing belt, it can make it jump time and there go the valves. I've personally seen this happen recently on a DSM.
The timing belt itself is pretty stout and should be good for at least 80k, weather tension is broken or not.
Myself, I like to err on the side of caution and I will be replacing the balance shaft and timing belts when I do my cams. Lancer shop has some nice heavy duty ones that I have been eyeballing for my upcoming cam install.
Old Mar 14, 2005 | 08:59 AM
HiHeatEVO's Avatar
thanks for the help y'all
Old Sep 13, 2005 | 09:12 PM
Deepseadiver's Avatar
So It is about a three hour job? Looking to install some 272's next week. Any help form someone in MD would be great.
Old Sep 14, 2005 | 05:05 AM
honda-guy's Avatar
Let me know,
g
pm sent
