would u thermo wrap?
Damn it
Wrapping the DP has nothing to do with preventing the oil pan from heating up. That's what heat shields are for. Wrapping the DP serves the sole purpose of preventing radiant disapation of heat - thus keeping hot exhaust gasses, hot. The purpose is to maintain optimal exhaust gas velocity.
Higher exhaust gas velocity, better torque...
Wrapping the DP has nothing to do with preventing the oil pan from heating up. That's what heat shields are for. Wrapping the DP serves the sole purpose of preventing radiant disapation of heat - thus keeping hot exhaust gasses, hot. The purpose is to maintain optimal exhaust gas velocity. Higher exhaust gas velocity, better torque...
I haven't wrap my DP, oil pan is designed to withstand high amount of heat. it's also sprayed with heat resistant coating.
I would say wrap up the IC pipe right in front of the DP. That's just rubber hose that heats up your intake air.
retarded engineering, i say.
5 c is nothing, vs, all the heat that's being absorbed to the FMIC rubber pipe in front of DP.
Your DP is air cooled by the front lower air induction tray anyhow. The undertray cuts off where the DP comes down and most airs are traveled to cooled the DP and the rest of the pipe.
But the front lower FMIC pipe is shielded by the FMIC and DP, so I would change that to aluminum and wrap it.
