Would anyone be interested in a shift lever extension?
Old Mar 3, 2005 | 01:55 PM
EVOTEXAS's Avatar
Originally Posted by gsujeff55
what penzoil stuff? you saying its better than mt-90? im interested.
synocromesh which is apparently the same thing as bg/gm syncroshift
Old Mar 3, 2005 | 01:56 PM
EVOTEXAS's Avatar
Originally Posted by schleppy
This does NOT shorten the throw at all, in fact, it makes it longer. HOWEVER, it reduces the effort needed to get the car into gears. I'd much rather have a lever that was easier to move in/out of gears than one that has a shorter throw, but feels like crap and takes much more effort.
This piece would really benefit those of you with a short shift kit that dropped the knob down too low. It would raise the knob back up, reduce the effort it takes to get in/out of gear and generally make the shifter feel better. All while having a shorter throw than stock
Plus, it will be pretty cheap too :-)
So, if anyone wants there shifter to be EASIER to use, let me know!
-Sean
Why not keep the same shifter or a shorter one and add a heavy shift knob? It gives leverage just the same but you don't have to move a longer distance to acheive the same result.
Old Mar 3, 2005 | 03:22 PM
bolsen's Avatar
not to jack the thread, but the bg was more like stock for me. I know the GM and Penzoil are the same.
Old Mar 3, 2005 | 09:45 PM
Want to Evo's Avatar
Short throw + Counterweighted Shift knob = The best set up for fast shifting. If you want to shift easier then I guess you can raise it.
Old Mar 3, 2005 | 09:55 PM
UT_Evo's Avatar
Originally Posted by bolsen
If a buttery smooth shift is what you want, change the trans fuild. It makes a big difference.
+200 I just got mine done with factory fluids at Mitsubishi for my 15k service... and holy crap, I didn't know I could shift like that!
Old Mar 3, 2005 | 09:56 PM
timzcat's Avatar
Buy a weight set or a bowflex.
Old Mar 3, 2005 | 10:05 PM
schleppy's Avatar
I've tried a heavier knob, and though it vastly improved the shifters feel, this extension makes it feel even better.
Old Mar 4, 2005 | 06:00 AM
bs's Avatar
bs
Ah yes the ever popular long shift kit
