MR BLOW OFF vs. STOCK BLOW OFF
is there a difference in sound (obviously with intake) between the stock and the mr valve. im thinkin of gettn something close to stock but nicer sound. also how does the mr valve hold?
I plan on ordering the MR diverter valve for my car, ive read that it holds boost alot better and is a lil bit louder, plus no welding needs to be done and wont cause stauling (like some aftermarket blow off valves) i'd say its well worth the 100 dollars and change!
sounds should be identical because they are both vent-to-intake design. That whooosh sound you hear is either coming through the air intake, or the BOV is a vent-to -atmosphere design, which as mentioned above may cause stalling because the MAS gets confused.
Originally Posted by blackevoVII
They sound similiar if not identical. I had the MR Valve. I do not suggest it with the HKS RS Suction Intake. It holds boost very well. I was pushing 22 through it.
Originally Posted by evo81
why replace it with another stock bov??? put some screws in there or something.
i think all bov suck anywayz.they all have there little problems
i have driven with the mr bypass valve for a while now, and no problem what so ever, great replacement for the stock vavle, it holds boost much better, and doesn t cause any stalling or bogging.
how much boost have you tried to hold with the mr?i wonder how much it could hold
Originally Posted by tke_413
Actually that's not completely true. The sucking sound when you're accelerating is from the intake, and the "whooosh" sound when you press in the clutch is not. It's the BOV or DV either venting to atmosphere (loud) or venting back in (quieter). The MR DV along with an intake will give you the air in/out sound without being too obnoxiously loud.
TxFAkuma
Feb 2, 2017 03:56 PM
TxFAkuma
Feb 2, 2017 03:53 PM
superscout03
Oct 13, 2006 05:27 PM
