Restrictor Pills
Old Mar 28, 2005 | 04:48 PM
chet's Avatar
Restrictor Pills
Do you re-use the restrictor pills in the wastegate vac line after installing an MBC? Can you just use new, normal lines without the pills?
Old Mar 28, 2005 | 04:51 PM
HoLeeRay's Avatar
you have two pills, only remove the one by the BCS, under your intake. and yes, you can simply replace the line, but make sure that you're using the same type of vacuume hose, size and whatnot.
Old Mar 28, 2005 | 09:12 PM
Jakeg97's Avatar
what he said ^^^^
or it wont work correctly
https://www.evolutionm.net/forums/sh...&highlight=mbc
