Problem with my gt3076r setup
Thanks guys. There are a lot of great suggestions. I am going to go get some new hose clamps and I took apart the bov and it was leaking and I am going to replace some of my silicone hoses. I will keep you all updated.
If you are running 18 to 19 degrees on pump gas let me ask are you running 19psi via map sensor or via boost controler? This is usually about a 1psi + or- difference. And with this turbo it will make a difference. Seems like a lot of timming for pump gas on a EMS though. Are you sure your knock sensor isn't pulling the timming back out of the car.
Did you log the AEM when you did the pulls so you could see?
i think you should remake your o2 housing... that thing has a shoulder on it... get a mandrel bent piece and just shave it until the dp fits.
can we get a complete parts list... that looks like a full race mani but why is it black?
I agree, that's a hell of a bend for a DP.
Did your car run ok with everything else before the turbo upgrade?
1. verify your injection timing map is correct & your firing the correct injector for the cylinder.
2. verify / data log your ignition timing & knock sensor activity.
3. verify that your a/f sensor is reading correctly
4. Try different gas
5. verify your boost is actually what your running.
6. verify your fuel pressure is as expected
7. verify your injector v. scalings are set-up correctly.
8. Once your happy that everything looks ok, turn the boost up. Less backpressure between the turbo & ex. valve with the system you have, should easily allow you to run more boost & or ign.
btw, based on your dyno numbers, your dp is the least of your problems.
Good luck
Good luck
Originally Posted by bolsen
running the ems, he doesn't even need an 02 housing. Just a DP and the wideband downstream.
Everything is set up on the aem right. I had a couple of leaks. One on the compressor housing where it connects to the chra and my ssqv was faulty. I fixed the leaks replaced all the silicone and clamps with better silicone and t-bolt clamps and did the pressure test over and every time I pressurized the system it would immediatly blow my pressure tester off the turbo so I got all the leaks fixed. I will go back to the dyno in a couple of days.
i just called it an o2 housing because that's what it's called if it's not a dp directly fit to the hot side. and i say it's restrictive because it is... it is a shoulder, that's bad... you can easily have a mandrel bent piece made... you just need to slice it close to the elbow... it was just an observation and a recomendation.
Originally Posted by strongbear0
I was running pump gas, afr of around 11.4 at wot and the timing was around 18-19deg at redline
Did your tuner use boost compensation mapping? Is knock control on? Did you log knock retard? Did you use internal logging? All your answers are in the log assuming you logged the proper parameters. Don't end up like a lot of unhappy ex AEM users, educate yourself.
Next time you get on the dyno make a pull and log everything otherwise you won't know what that ECU is doing. Your freind sounds good so he should know. That just sounds like alot of advance for 19lbs but if you are only running 14lbs or so it sounds better. You should log knock with the internal log at 250samples per second so you can see each ignition event to make sure, you would never be able to tell just by watching the parameters box becuase it happens so fast. I hope you get it lined out, well I am shure you will get it lined out.
You should learn everything you can about you AEM though that way you can know exactly how safe everything is and you will know alot of the answers to your questions.
Good luck.
Good luck.
Good luck.
Good luck.
