High flow cat to test pipe.
Old Mar 31, 2005 | 09:11 PM
LateSleeper's Avatar
I currently have a 3" high flow cat with my turbo back exhaust. Would a 3" test pipe thow off a tune? I did a search and found nothing. Thanks in advance for any help.
Old Mar 31, 2005 | 09:13 PM
johny719's Avatar
is ur car tuned to the High Flow? or did u not tune it yet? the turbo back shouldn't throw off the tune... it will make your mpg go a bit lower...
Old Mar 31, 2005 | 09:18 PM
Iceman2011's Avatar
The test pipe will flow more air out hence it will throw it a little but not enough to make you feel a difference, it will just run a little richer and alot louder
Old Mar 31, 2005 | 09:22 PM
If running a test pipe from a high flow cat causes the car to run slightly richer then is should be safe then, right? I shooting for turbo response.
