leaking throttle body
Old Apr 3, 2005 | 09:53 AM
Novtec1's Avatar
Veteran: Army
went down to dallas yesterday to get tuned by mark for turbotrix got most boost i got out the car on the way down was 20.5 and it was set for 21. i justhought it was l lil warm and didn't think about it. get the car on the dyno, first pull 16 lbs, next 14 next 17 so we take the car off let it cool of i check all the hose and we decide to to a pressure test and hear air coming out the throttle body.... mark said this was a common problem on 1g DS's but he never seen it on a evo. anyone know anything about this.? any help would be appreciated.
Old Apr 3, 2005 | 09:58 AM
TrinaBabe's Avatar
Chances are it is just the hose clamp holding the upper IC pipe to the throttlebody. Use a T-Bolt clamp and it won't leak. Hair spray also helps out.
Old Apr 3, 2005 | 10:22 AM
Novtec1's Avatar
Veteran: Army
nope its not that... it comes from the throttle body and when you tighten the throttle down it stops leaking. everyone thinks is the shaft the butterfly is bent or something. im gonna pull it off and look at it today
Old Apr 3, 2005 | 11:34 AM
Deepseadiver's Avatar
Keep us posted. (us = people with boost problems)
Old Apr 3, 2005 | 01:01 PM
Novtec1's Avatar
Veteran: Army
well i found my problem... leaking tb gasket..... got into boost at idle my friends sprayed some carb cleaner in it and we found the leak.. at the top of the tb. so tomorrow i'll order some new gaskets.
Old Apr 3, 2005 | 06:52 PM
yesevo's Avatar
how to put load (boost) on idle?
Old Apr 3, 2005 | 09:22 PM
^^ Not at idle Mabye he was on a dyno?
