What kinda tune for cams?
I was thinking about getting the GSC sometime this week and was wondering what kind of tune will I need? Will a SAFC II be good enough? Oh and I was going to get the 272/264 combo.
You can tune for cams with a S-AFC2 however you probably won't utilize all of the cams capabilities until you get an AEM system, flash, or piggy back ECU so you can adjust for things like timing.
S-AFC2 can be configured for cams but you're only effecting air/fuel by adjusting the air flow.
If it is the same system used on the Subies, then yes, that will be more than adequate. BTW, I live 5min from Topspeed when I am home from college, maybe I will see you around.
sti"izzle"
Sep 21, 2010 01:31 PM
