GSC 272in\264ex w/Cam gears
I'm going to do this mod soon. I have a pair of AEM cam gears. What settings should I put adjust the cam gears to get the most power on average. I will have XEDE on the car when I do it.
Check out some other threads with the guys who have tuned GSC cams. I know for 272/272, -4,-1.5 is a good timing, but im not sure on the 272/264. Oh well, im sure someone will help u out on this one.....good luck!
Trying to get all I can get out of them. Youjust hate to go that far, to have not done cam gears is crazy. I could swap turbos in the future, and adjust the cams gears ASAP, instead of wondering what I could get out of the cams if I had gears.
Originally Posted by turboex
Why run cam gears, alot of people are running this combo so they dont have to use cam gears. Or are you just trying for that extra few hp? I could understand that too.
Idle is fine with a good tune. You do not need to run cam gears. I run the 272/264 with a reflashed ECU. Car runs great. Idle is a little lopy, but that is to be expected with running a agressive cam set-up.
