INTAKE: HKS rasing suction or ARC indution box
keep 'em coming guys/gals.
i still can't decide from either of these.
i know, or have heard, that you have to change the filter for the HKS racing suction intake every 3000 miles.
how about for the ARC induction box, do you need to change the filters, or can you just clean them?
also, for people with any of these set-ups, did you notice any power gains and was there any driveability issues?
-john
-john
Originally Posted by boostfed
are you using the stock intake tube or does the arc come with one.
-Chad-
-Chad-
the arc just allows quicker airflow than stock
meaning quicker throttle response
/ but not as quick as the hks rs
Originally Posted by 04Evo8RS
ARC definately looks the best out of any intake for the evo and its supposabely a awesome product id go with that..!
-john
-john
Looking to purchase the ARC setup and was curious as to what type of filter element it is?
Does anyone have the ARC installed yet? how are the gains and any problems with the computer after install?
Originally Posted by umiami80
Your forget to factor in the MASSIVE ducts and vents on the Nose and hood of the evo. It is designed to suck up the air and blow it through the hood, your fine, especially at 70++++MPH.
HKS foam filter only good for blocking small dogs from entering your intake.
I run MAFless however I will not be going to a cone filter - I think they suck up too much ambient heat. And I live in a very hot climate. I will be retaining the stock airbox, putting a K&N panel filter in it and running a hard pipe straight from the bottom of the box to the turbo.
Im very happy to retain the stock ram air effect which must be considerable at 100mph. Just try sticking your hand out the window. I think aftermarket airboxes are for bling and have no practical value.
Dyno tests have shown considerable improvement with aftermarket intake over the stock intake.
100mph may be better for stock intake, may not, there is no evidence. Doesn't matter to me, as I rarely see over 100mph anyway.
