Worth installing 02 housing?
Old Apr 8, 2005 | 02:00 PM
EVIL_EVO_VIII's Avatar
Hey guys wondering if its worth installing an 02 housing? I bought one, but the only reason i bought it was b/c my friend got some custom made stuff on his Evo and never installed it and sold it to me for $40 brand new!! Thanks
Old Apr 8, 2005 | 02:04 PM
SilverStreak's Avatar
Definately! I noticed a HUGE difference when I put mine on. It's a pain to install, but it's worth the effort. The turbo spools in about half the time it did before and the torque is much improved. You won't be disappointed!
Old Apr 8, 2005 | 03:12 PM
Thanks!
Old Apr 8, 2005 | 04:44 PM
WHTEVO's Avatar
i don't have one on my evo but have one on my talon and i too noticed a difference. go for it.
Old Apr 8, 2005 | 05:14 PM
yesevo's Avatar
stick with stock cast o2 housing ...just get ported and coated. its only $225 for the service from buschur. aftermarket o2 housing ll crack later on.
Old Apr 8, 2005 | 09:59 PM
timzcat's Avatar
So you are hitting full boost at 1750 RPMs?
Go with a ported stocker. Not only will it last but it will also support the weight of the turbo.
Old Apr 8, 2005 | 10:43 PM
Evo Police's Avatar
I've heard alot of people stress this. Anyone here had buschur do the porting to there O2 housing? Whats the turn around time from when you mail it away?
Does any other vendors do O2 porting and polishing?
Old Apr 9, 2005 | 05:45 AM
yesevo's Avatar
it will take mine around 2 weeks.
Old Apr 9, 2005 | 06:02 AM
snapb1's Avatar
I have heard people say it is a good mod and others say it isn't...someone needs to put one on and dyno.
Old Apr 9, 2005 | 06:36 AM
n2mprtz's Avatar
Talking chk ebay
I bought my Megan Racing O2 housing for $90.00 on EBAY, and it is worth it. more HP, and a sooner spool-up ... $90.00 well worth it.
Old Apr 9, 2005 | 07:16 AM
evo_dadi's Avatar
like what timcatz posted use a ported stock o2 housing since it has a separate bracket for mounted to the engine so it doesnt add to the weight of the turbo hanging on the exhaust manifold.i didnt found out about this till later after i had an aftermarket o2 housing installed already.but im in the process of sending my stock housing to buschur to get ported and jet hot coated.
Old Apr 9, 2005 | 07:24 AM
sleet's Avatar
Do you notice any gains from getting the stocker ported and jet hot coated?
Old Apr 9, 2005 | 07:28 AM
evo_dadi's Avatar
i havent sent it yet but ill post the difference when i do but with the stock turbo i noticed the big o2 housing was an overkill ti will give you more exhaust flow but sacrificing some torque down low.the coating helps both ways:cooler engine bay since the radiant heat gets dropped down a bit and a faster exhaust flow.
Old Apr 9, 2005 | 08:10 AM
humpevo311's Avatar
since when does it hold the turbo's weight last time i checked the downpipe bolted too it? Alot of cracking is most likely caused by rigid dp's with no flex sections bending against it.
Old Apr 9, 2005 | 08:15 AM
sleet's Avatar
Alot of reasons why after market o2 housings break and whatnot is because they only have 2 bolts and the stocker has 3. This doesn't make it as strong as the stocker because it doesn't have as much force holding it on. Works is in the process of making a new o2 housing with 3 bolts, if anything I would wait for that.
