Improved Power AND Fuel Economy
Old Apr 11, 2005 | 01:50 PM
Ted B's Avatar
Again, let me make it clear that it isn't as much about the cams themselves as it is the cam timing, and how it affects volumetric efficiency.
Old Apr 11, 2005 | 01:53 PM
sleet's Avatar
How much of a difference would I get with upgrading from the stockers to 272s, about the same aslong as I stay out of boost?
Old Apr 11, 2005 | 06:12 PM
Jorge T's Avatar
Ted, no stalling issues with A/C on?
Old Apr 11, 2005 | 06:15 PM
housedj's Avatar
i'm sure the humidity there is also doing wonders for your intercooler efficiency. glad the cams work. how much more were they over the 272's? how different is the lift duration?
Old Apr 11, 2005 | 10:01 PM
EvolvedfromaWRX's Avatar
Wow...that sounds really excellent!! congrats!
Old Apr 12, 2005 | 06:25 AM
Ted B's Avatar
All the HKS cams (264, 272, 280) have the same lift. The only difference between them is duration.
I haven't had any real stalling issues with the A/C on. The fast idle circuit jumps in when the A/C is switched on, and does a decent job of compensating.
So far, I've had the stock cams (obviously), 272s, and now 280s. I've noticed only an increase in fuel economy after upgrading the cams (along with exhaust and other mods) AND a good tuning.
Old Apr 12, 2005 | 07:08 AM
jj_008's Avatar
Originally Posted by SuperHatch
Ted,
I went with the 0/-2 setting with my 272's this weekend as we talked about. Same tight LSA as your 280's but retarded some to get some more top end. Needless to say my results were very good. I'll be running at the track this weekend to see what she'll do.
- Steve
Ted, what is your opinion on this cam timing for my 272's w/ a bigger turbo? BTW, good job on the excellent fuel economy. With my stage 1+ I can get 300 miles to the tank w/ highway driving.
Old Apr 12, 2005 | 07:25 AM
bolsen's Avatar
Ted, is this on a stock head?
Old Apr 12, 2005 | 07:32 AM
lil'evil_evo's Avatar
Originally Posted by BigAeVo
Wow 340? i only get about 240 probably maybe not even that for a full tank
no $hit, i only get 250 max all highway
Old Apr 12, 2005 | 07:35 AM
Originally Posted by rsboy
Damn it.... i guess I will have to think about upgrading my cams then... just for the increased gas mileage!
To think.. I was "almost" done with mods.
don't get to exceited, i think this guy is one of if not the only one that can speak of this.
Old Apr 12, 2005 | 08:45 AM
marksae's Avatar
Ted, how is your gas mileage for city driving? Or in stop and go traffic?
Old Apr 12, 2005 | 09:23 AM
Ted B's Avatar
My cylinder head is bone stock.
I'm observing an improvement in across the board fuel economy. My mixed hwy/cty appears to be almost 300 miles per tank. Last night, in hilly terrain with windy, rainy weather, I still managed 350 miles despite being weighted down with a full trunk.
As far as the 0/-2 setting for 272s, it should work well if the idle is acceptable.
Old Apr 12, 2005 | 09:29 AM
jj_008's Avatar
Thanks, Ted. I will make sure to have them adjusted when Shiv tunes it next weekend.
Old Apr 12, 2005 | 09:08 PM
go_evo_go's Avatar
Is the cam timing the difference? Do you think that it would work with any evo or do you need the same mods as you? That would be great to get that much. Thanks for the info.
Old Apr 12, 2005 | 11:59 PM
trinydex's Avatar
hey have you tried uhm... silversurfer's -4/-1 setup... he also claimed more low end and stock idle, better than stock in fact plus a lotta other lalalala ... i can't remember everything he said but i'm very interested in cam timing...
i know that the seperation keeps idle liveable... as long as you keep the overlap apart by 2-3 degrees.... but silver surfer has his numbers flipped from yours... are you guys sayin' the same thing? which is exhaust and which is intake? (this was directed at superhatch)
and then silversurfer said that you should never go to the positve end... but obviously ted has gone to the positive... i'm not sayin' silver surfer is all knowing or anything... i actually advocate against the single spring mod in the greddy type-s but he did make some interesting reading with the cam timing before this post here...
more info please!
https://www.evolutionm.net/forums/sh...timing+testing
here is that thread btw.
