Peak boost for 2005 Evos??
Old Apr 13, 2005 | 11:02 PM
JT-KGY's Avatar
Whats the peak boost everyone getting on 2005 Evos??
I'm getting as high as 1.53 (22psi??) on my Blitz DTT turbo timer.. the same timer
was only reading about 1.39 max on my 03s... My oem sports meter boost
gauge also read about the same thing..
I know that 05 has a slightly bigger turbo housing.. but did that also change the
peak boost?? Or it's just my gauges highly inaccurate....???
For one thing... I got a very long vacuum hose route from the engine to inside
the cabin..
https://www.evolutionm.net/forums/sh...d.php?t=133346
Any opinions from 2005 owners??
Old Apr 14, 2005 | 02:17 AM
JT-KGY's Avatar
Car is completely stock... No exhaust.. No mbc/ebc... No aftermarket BOV...
The long vacuum line is from the oem sports meter boost gauge... the oem boost
gauge vacuum hose is then T'ed to add another line for the Blitz DTT.
Old Apr 14, 2005 | 02:20 AM
JDM-Spec.com's Avatar
1.6 bar, but I reach fuel cut when its cold out, need to get a reflash to remove fuel cut.
Old Apr 14, 2005 | 02:21 AM
JT-KGY's Avatar
Nice... but is that possible with completely stock car like mine?
Mine doesn't hold at that boost.. just spike to it...
Old Apr 14, 2005 | 03:11 AM
350Z_2_Evo8's Avatar
Mine peaks at 19psi...i got a carbon fiber autometer boost gauge...
Old Apr 14, 2005 | 05:46 AM
Drifto's Avatar
A spike to 21-22psi sounds about right.
Old Apr 14, 2005 | 10:17 AM
Jamie@WORKS's Avatar
the cabin..
This is exactly what we saw on the WORKS MR when it was bone stock. Our P2 Brain Flash helped settle that spike (and keeps the boost from tapering ).
Old Apr 14, 2005 | 11:30 AM
JT-KGY's Avatar
So this is normal?? That is so strange...
My 03 will spike over 1.35 RARELY... I mean... I have to
really "try" to get it to spike that high...
With the 05s... I can easily hit 1.50...
Must be the updated turbo housing on the 05s then?
Old Apr 14, 2005 | 06:28 PM
white05evoVIII's Avatar
i have a defi d-spec boost gauge and i see that my 05 spikes to about 20 psi, but i also have a hks ebc. even when it is set at 19 psi it will spike to about 20 psi the go down to about 17-18 psi. i will also hit fuel cut when it is real cold outside.
Old Apr 14, 2005 | 06:31 PM
JT-KGY's Avatar
20 psi is acceptable as stock should already go up to 19.5 psi...
But 22psi?? I think it's gauge error... but both gauges are reading the samething..
Old Jul 30, 2005 | 12:55 PM
hc434's Avatar
I see the same problem as well w/ my 05 stock evo. I'm using the Defi boost gauge, and it spikes to 21, but drops down to a stable 19. I was wondering if this is normal as well.
Old Jul 30, 2005 | 01:10 PM
Erik@MIL.SPEC's Avatar
Peak boost is supposed to be something like 20.5 or something. 21 should be ok without tuning for a spike.
Old Jul 30, 2005 | 08:41 PM
althemean's Avatar
I get the same 21 psi spike. Confirmed on a dyno and the gauge. Sounds normal to me.
Old Jul 30, 2005 | 09:27 PM
MRevo05's Avatar
i get 21.5 on my MR with just bolt ons
Old Jul 30, 2005 | 09:37 PM
Blue Evo 8's Avatar
when my car was stock it was boosting 1.5 bar.
After I put on a 3" test pipe and 3" cat back, I saw a spike of 1.55 bar.
Now I'm trying to set up my EBC to spike to 1.5 bar and hold as much as possible to redline.
