BOV leak
Old Apr 15, 2005 | 10:35 AM
rartist's Avatar
Question BOV leak
I have a stock BOV on my 03 that I'm strongly suspect of it leaking. I run it up 3-4 grand in 4th and can hear the BOV sound power on. My boost gauge shows me making about 10psi max (engine hot). Cold I see 14-17 psi, but it heats up real quick.
Is there a way to check the BOV for proper action?
I'm almost certain I can hear the fraking thing blowing under throttle, and I'm missing lots of mid range power. A visit to the dunderheads at the dealership found nothing wrong while it was hooked up to their computer.
Old Apr 15, 2005 | 10:46 AM
matt55's Avatar
1st your psi is way low , 2nd Ive found my stock bov to leak at 12-13 psi when pressure testing my system , any mods?
Old Apr 15, 2005 | 12:00 PM
PVD04's Avatar
I tested mine when I leak-tested my intercooler piping. The only way to test it is to put the same pressure on the valve and the small nipple. I found this easiest to do while it was still attached to the car. The result of the test is that it began leaking at ~13-14 psi.
-Paul
Old Apr 15, 2005 | 06:25 PM
rartist's Avatar
No mods, I need to get what I have running well first.
One dealer told me 9-10 psi is ok. I don't buy that.
Old Apr 15, 2005 | 06:31 PM
krafty's Avatar
http://www.vfaq.com/mods/ICtester.html
