Stalling @ idle, only with AC running ...
Old Apr 18, 2005 | 12:15 PM
raymerd's Avatar
Folks,
Looked around for this on a previous thread, did not find it -- if its there, please point it out to me. My mods are below in my .sig. When I go home tonight, I'm going to double check my HKS RS intake install for leaks on the intake path, but after the Evo has been running for about 20 minutes or so, if the AC is on, I get stalls -- RPMs drop below 500, sometimes it recovers, sometimes it doesn't.
Currently, normal idle seems to be around 850rpm (according to engine data scanner).
thanks --
dave
Old Apr 18, 2005 | 01:59 PM
BaLListic_EVO's Avatar
i recall hearing someone say that the car has a high idle sensor for when the AC comes on perhaps yours isnt working properly?
Old Apr 18, 2005 | 02:56 PM
bigjhoney's Avatar
Has the problem ever occured with the a/c off?
Old Apr 19, 2005 | 06:38 AM
raymerd's Avatar
When my cam gears were not installed correctly, yes (since corrected). When the ECU had been reset, yes (like right after I installed the racing suction intake and didn't let it idle for awhile before trying to drive it -- DOH!) But not under normal driving conditions that I remember. This problem has been going on for several months now, its just gotten worse recently.
I did some testing yesterday and this morning -- its definately related to load on the engine @ idle. I stopped by the dealership and talked with their evo techs; they agree that it is either a vacuum leak or the idle control sensor/servo assembly on the throttle body. I haven't had a chance to thoroughly check for the vacuum leak yet (having to work really sucks). I did a cursory check last night on the lines that are easily accessible and neither heard (using a lenght of hose) or found (using some soapy water). I'm not likely to get a chance to work on it again until at least Thursday night.
I'm going to take my Evo to the dealership on Thursday and get the sensor/servo assembly checked on their diagnostic system. If its the sensor/servo, its a $300 part ... blah
I'll post back what I find later in the week.
Old Apr 19, 2005 | 06:43 AM
Smogrunner's Avatar
what kind of BOV are you using?
Old Apr 19, 2005 | 06:45 AM
raymerd's Avatar
Stock BoV with stock hoses/piping. No change there .... my understanding is that the stock BoV is good to about 25psi, and I'm running 22 at peak, with a taper down to about 19 . Taper was worse before I replaced my clutch and flywheel.
-- dave
Old Apr 22, 2005 | 06:49 AM
raymerd's Avatar
ok, so I've pressurized the intake side of thing and found a single small leak on what seems to be the negative pressure line leading into the wastegate solenoid, fixed that and idle is marginally better. When it does drop, it tends to stabilize out a 600rpm, the climb back up. I've stalled it once in about 60mi of driving, but I think that may have been me being a spaz.
Bottom line is that the idle is better but still not good. I've got a 3:30 at the dealer to get the ICS coils analyzed/checked.
I'm open to suggestions, this is driving me nuts.
thanks,
-- dave
rich3389
Sep 8, 2024 07:27 AM
YoitsEVOSAL
Jun 11, 2011 02:28 PM
alpix715
Aug 30, 2010 03:13 AM
joedr
Aug 22, 2008 01:11 PM
PPI
AEM EMS
Apr 21, 2006 09:02 AM
