AEM EMS Get tuning help for your AEM EMS system.
Help me fix my stalling issues please
Old Apr 14, 2006 | 08:54 AM
PPI's Avatar
PPI
Sinced i have been driving my newly tuned aem, many times when i am decelerating and coming up to a light (just for example) as soon as i push in the clutch and take the load of the engine the rpms fall below the idle speed. It always starts right back up and idles fine.....but it seems whenever i push in the clutch and let the rpms drop the and the idle drops really low, sometimes it will come back up to 1,000 (roughly my idle speed) but sometimes it acts like it doesn't find the rpm speed and just stalls.
Any help with this would be great. Taking it to a tuner around here is not a option unfortunately. -Wayne
Old Apr 14, 2006 | 06:42 PM
PTevo's Avatar
I'm having the same problem with the stock ecu. Good luck. Try checking the EGR connections (emission solenoid) at back of engine. A loose rubber hose could cause some problems similar to yours.
Old Apr 14, 2006 | 08:05 PM
PPI's Avatar
PPI
I played around with my idle map today....seems to be better. It didn't stall on my test drive....we'll see how it holds up.
Old Apr 18, 2006 | 05:59 PM
Spaceball 1's Avatar
send me your calibration and a log at idle with idle target and idle actual i can take a look
I would check your Idle FB min set to 0 and lower your target idle down till it gets to your car idles at the correct speed. also check the ign timing and AFR at idle.
Old Apr 18, 2006 | 08:13 PM
evolved4g63's Avatar
http://forum.aempower.com/forum/index.php?topic=12280.0
Reply # 7 helps
Old Apr 21, 2006 | 09:02 AM
PPI's Avatar
PPI
thanks, i am leaving town for a week and when i get back i will get those to you....I have not played with sending maps or logs yet....
rich3389
Sep 8, 2024 07:27 AM
GaminKWB
Lancer Engine Management / Tuning Forums
15
Oct 21, 2016 03:48 PM
BlackDismay
Dec 12, 2011 06:05 PM
hotredevo
Jul 29, 2010 06:54 AM
binh
AEM EMS
Mar 1, 2007 09:45 AM
