View Poll Results: Which color spring are you using with the Forge Diverter (recirc.) Valve
Green (softest)
6.25%
Yellow (what comes in it)
25.00%
Blue
25.00%
Red (stiffest)
43.75%
Voters: 16. You may not vote on this poll
Forge DV: Which color spring are you using?
Originally Posted by JustDSM
True... Another question would be.. How much time if any, was spent with the car at part throttle under boost (during Dave's testing on the RS)?
"The [Forge DV] kit comes with a variety of springs. I use the heaviest spring in the kit and was very happy with the performance of the valve. I have it on my RS. The car with the lightest spring had some serious driveability problems, surged like made. With the heavy spring I find it to be very smooth.
David Buschur"
Sounds completely backwards to me [stiffer spring causing less surge], but what do I know.
The stiffer the spring the more surge you will get. Also, the stiffer you go the worst driveability becomes (stalling, low RPM on idle). I have ran the yellow spring, no shims, at 23 psi w/no issues. When I installed the red spring, for high boost runs w/ the 3076, my idle dropped and I even had some stalling.
Yellow spring is good.
