APS BOV, NEED ADJUSTMENT>?
Old Apr 25, 2005 | 03:49 PM
yesevo's Avatar
anyone cut the rubber hose alittle bit where bov seats? prior to install?
Old Apr 25, 2005 | 06:32 PM
zstryder's Avatar
How loud is this BOV at the out of the box setting? I have a Greddy TypeS, I love the drivability and I don't want to give it up, but I'd like a little more sound if possible.
Old Apr 25, 2005 | 06:41 PM
BoostWhore's Avatar
I think the greddy would be way louder
Old Apr 25, 2005 | 06:52 PM
zstryder's Avatar
I have it in recirc mode, though.
Old Apr 26, 2005 | 09:35 AM
RallySport Direct's Avatar
Silver Sponsor
Originally Posted by zstryder
30/70 = 30 VTA, and 70 recirc?
It actually adjusts how much to let off into the atmosphere or recirc by how much boost you are running. So it cannot be called a 50/50 75/25 or anything like that because it is constantly changing to give you the best performance.
Ben
(settings from the factory are almost perfect in 95% of cars. some people like to adjust them a little but it is not required.)
Old Apr 26, 2005 | 09:49 AM
zstryder's Avatar
Ben
Oh? So now we have active variable pressure BOV's eh? The wonders of technology.
Sounds pretty cool though, I just wish BOV's had a "test drive" option...
Old Apr 26, 2005 | 11:30 AM
lil'evil_evo's Avatar
does anyone have a sound clip?
Old Apr 26, 2005 | 01:58 PM
yesevo's Avatar
..if u hit the boost more than 7psi, wooshi~~~
at 20psi, WHOOOOOSSHHHH~~~~~~~~~~
if u drive w/ window down... WWWHHOOOOOOOOOSSSSHHHHHHHHH~~~~~~~~~~~~~~~~
Old Apr 26, 2005 | 02:09 PM
Silver Sponsor
http://www.rallysportdirect.com/shop.../APS%20BOV.avi
Ben
Old Apr 26, 2005 | 02:13 PM
zstryder's Avatar
Question. So if this is a variable BOV, how much is recirculated and how much is VTA at any one point? What determines the "optimum" amount, and how can you change that?
Old Apr 26, 2005 | 02:20 PM
Silver Sponsor
It is just set up so the more pressure you have in the system the farther the piston opens to release out the secondary port. The ports are offset so you will get to the recirc port before the secondary port. And if you take you finger and push the piston in the valve you can push it so the secondary port is almost all the way open. sorry I my describtion is not very good. You can check out the one on our site.
http://www.rallysportdirect.com/shop...230d415cdd4f31
Ben
Old Apr 26, 2005 | 02:24 PM
zstryder's Avatar
Ah, I get it. So under low boost, it recirculates most of the air, but once you build lots of it, it'll both VTA and recirculate? Interesting... and absolutely no fluttering/surging problems? I just might have to get one of these..
Old Apr 26, 2005 | 02:31 PM
yesevo's Avatar
no problem at all...i love this aps...
the one thing i dont like is that the neck on aps is abit shorter compare to stock one.
if it is longer , you ll get seal better by putting rubber hose farther in.
Old Apr 26, 2005 | 02:47 PM
GP's Avatar
GP
No complaints here, APS all the way...
It actually cured the stalling problem I had with JDM MR Bov.
Old Apr 26, 2005 | 03:06 PM
yesevo's Avatar
anyone have their intercooler?
