i need more help please
Old Apr 25, 2005 | 02:06 PM
thadon84's Avatar
I just had a new act clutch and light weight flywheel installed in my evo. im past the break in and now when im at wot in third gear, and i go to shift into fourth at 7 grand i engage the clutch and the shift is like sticky almost like i have to force it out of third and it makes a knocking/clicking sound almost. and the same exact thing happens in fourth trying to go into fifth. there is no problem shifting under normal driving conditions though. any ideas what the problem is clutch? synchro?
any help would be great
thanks
Old Apr 25, 2005 | 02:13 PM
thadon84's Avatar
bump
Old Apr 25, 2005 | 02:22 PM
thadon84's Avatar
help help me please
Old Apr 25, 2005 | 03:11 PM
Nad1370's Avatar
Clutch pedal not adjusted right or maybe you need to bleed the clutch system for air pockets.
Old Apr 25, 2005 | 06:34 PM
bolsen's Avatar
I was thinking adjustment as well
Old Apr 25, 2005 | 07:31 PM
thadon84's Avatar
i was hoping that was all it is but for the life of me i cant spin that rod after i loosen the bolt. ive read the how to on the clutch pedal but for the life of me i cant get it to move
Old Apr 25, 2005 | 07:48 PM
timzcat's Avatar
pedal adjustment.
pull the pin at the pedal so you can spin it.
Old Apr 26, 2005 | 02:52 PM
Nad1370's Avatar
There's no bolt to loosen, just a 12mm nut. Kung-Fu grip that sucker and turn the rod. Just make sure your not bottomed out yet.
Old Apr 26, 2005 | 02:58 PM
thadon84's Avatar
bump
Old Apr 26, 2005 | 02:59 PM
thadon84's Avatar
what do you mean by bottomed out and yes i meant nut
Old Apr 26, 2005 | 03:03 PM
Nad1370's Avatar
Meaning there's no more threads showing in the rod to adjust.
Old Apr 26, 2005 | 05:57 PM
timzcat's Avatar
that's why it's easiest to just break the nut loose and pull the pin out at the pedal so you can easily adjust it. You definitely need to adjust it and I believe it comes with direction to that effect.
Old Apr 26, 2005 | 09:29 PM
thadon84's Avatar
i finally did get it and it fixed the problem thanks timzcat and nad
