What PSI on Race Gas (Stock turbo)
Old Apr 25, 2005 | 10:47 PM
IS2000's Avatar
What would be a good boost level for 100 octane unleaded?
Old Apr 25, 2005 | 10:51 PM
2befast's Avatar
probably not more than 23psi. back to the topic. i thought leaded gas is bad for our evos. I thought we can only put unleaded in our cars. Does the leaded stuff harm anything
Old Apr 25, 2005 | 11:19 PM
Blitzbaster02's Avatar
you can do 25psi on 100 easily. I run 22psi on 93 with no problems at all. Leaded fuel will only wear out your o2 sensor, thats all.
Old Apr 26, 2005 | 05:42 AM
Turbo13's Avatar
I have not cat and my o2 sensor is pulled out so it won't make a difference. It think I will try 26 ish.
Old Apr 26, 2005 | 09:09 PM
2befast's Avatar
anyone else on this topic would be cool
Old Apr 26, 2005 | 09:13 PM
Nesiop's Avatar
This is on all stock internals right? The 25-28 psi right?
Old Apr 26, 2005 | 09:19 PM
rebelzx's Avatar
Crank it up as high as the stock turbo will push. jJust make sure you are using a good leaded fuel.
Old Apr 27, 2005 | 12:26 AM
Evoisdream's Avatar
is thier any danger in leaded fuel other then the o2 sensors?
Old Apr 27, 2005 | 04:31 PM
ct9a gsr's Avatar
On a 50/50 mix of VP c16 (116 octane leaded) and Shell 93 octane, I run 30psi spike with no problems or knock. I'll be having my methanol injection setup to do the same on 100% 93 octane.
Old Apr 27, 2005 | 04:41 PM
VTECH8TR's Avatar
Originally Posted by redevo561
^^ what octane were you using ?
I am running a Buschur stage 4 with 93 octane and 100% methanol. 28 psi tapering to 23 by 8,000 rpms . The Intercooler lets you run more boost while keeping the temps down.
Old Apr 27, 2005 | 05:26 PM
Evoisdream's Avatar
so im thinking im gonna run 110 and do like 26 psi sound safe?
Old Apr 27, 2005 | 07:48 PM
Turbo13's Avatar
So if I were to run straight 116 or 118 leaded you think I could run 30 psi safely huh?
Old Apr 27, 2005 | 10:51 PM
Evoisdream's Avatar
i think u can totally the thing im finding out from a lot of the local tuner guys is that the stocker isnt really efficient over like 26 and starts to blow hot air so u will end up not making any more and possibly less at like 30 psi
Old Apr 27, 2005 | 11:56 PM
DrEvo's Avatar
With the stock turbo I had my set up spike up to 27-28 psi w/out any issues. This was on C16 and using ECU+ for fuel/timing. So if you are just dumping the fuel and raising the boost, you should be fine. This was done with stock injectors and walboro 255 fuel pump, fuel set up. The only difference between your current set up and my old one was a FMIC, which would help you a lot. You will be pushing that turbo pretty hard, so the air is just going to get hotter. FMIC would help, but you can get away without it. Also when I replaced my stock turbo for my SC61 set up, I checked for shaft play and there was none. I was pretty surprised since I ran that poor thing hard. Also, just so you know, RACE GAS IS ADDICTIVE WHEN COMBINED WITH HIGH BOOST!!
