need some help.. only running 4 - 5 lbs boost
Old Apr 29, 2005 | 10:58 PM
chinto's Avatar
ok for the past month or so iv been haveing issues with boost slowly droping more and more .. so what iv done / found so far is
found a rip in the diaphram in my greddy type - s bov couldnt easly go with a repair so.. i replaced it with a 1g bov. holds boost great did a preasure test had a small leak around the throtel bodie i couldnt find didnt worry about it.. boost seemed to hold better was all happy
few days later boost started falling again dont know why.. nothing changed i tryed changeing settings with avc - r tryn to pump the boost up worked kinda but shortly after stoped
today i said screw it went to dsm told them what was up they said to try a mbc so i got it and still not holding boost did a nother preasure test finaly found the leak when i went to pull the vacume line off it actually broke in my hand i was like wow YES found my issue ( preasure tested again no leaks that i can hear or feel any where )
put new vacume line on with mbc now and still not boosting over 3 or so psi
sorry for long storie
i tryed every combo of vacume hose' that i could with wastegate turboside nipple and bov line does not matter still cant boost.
need some help on what to do next i dont think it was any thing i did i only have about 500 miles till my warrnty expires with mitsubishi should i take it back and say fix it and if its something i broke ill pay im starting not to care any more i just want boost back cuz i feel like im driveing a normal 4banger and it sucks
any one have test or something i can do.. for the waste gate or something else i can try
and i dont know if this is related i keep getting a 0420 check engin light mitsu is telln me its a bad cat code so on the 10th they say they are going to replace hopefully to fix the light
Old Apr 29, 2005 | 11:31 PM
timzcat's Avatar
Sounds like the wastegate is open. Maybe damaged or broken actuator rod. To only get 3 psi (if gauge is accurate) it would almost have to be the wastegate. Wastegate running on spring pressure alone is 11-12 psi so it sounds like it is open or not connected to the actuator.
Old Apr 29, 2005 | 11:38 PM
timzcat's Avatar
An easy testyou can try is to disconnect the hose that goes to the wastegate actuator.
Very carefully drive the car and bring on the boost. If you still don't go past 3 psi then the wastegate or actuator is screwed up. If you have boost again then it is boost control problem.
Old Apr 30, 2005 | 07:47 AM
chinto's Avatar
thanks ill give that a shot.
aight tryed that.. still no boost.. what now? is the wastegate / actuator rebuildable if i took them off and moved them would it fix it?
Old Apr 30, 2005 | 09:02 AM
chinto's Avatar
bump any more help?
Old Apr 30, 2005 | 09:35 AM
chinto's Avatar
hopefully last question in any way could a boost controler make the wastegate or activator go bad? tryn to see if i should fix it my self or try to get mitsu to
Old Apr 30, 2005 | 09:43 AM
Curt@MrLed's Avatar
Former Vendor
if you can but i doubt post a pic of the housing without the shield.. when you pulled the arm off the wastegate could you move the little flapper.. we can prob help you we just need more info... were not looking at the car...
Old Apr 30, 2005 | 09:47 AM
Curt@MrLed's Avatar
Former Vendor
well..
Old Apr 30, 2005 | 09:50 AM
chinto's Avatar
i dont have a digital camera.. take the shield off of what i have limited knowledge bacicaly what im told ... im pritty mechanical what i take a part i can put back to gether.. i just dont know what to be looking for or at.
Old Apr 30, 2005 | 09:51 AM
Curt@MrLed's Avatar
Former Vendor
ok, haha.. tell me this could you move the actuator arm .. ill im you..
Old Apr 30, 2005 | 11:47 AM
chinto's Avatar
ok.. got to the waste gate flap and it moves freelly.. so that means its the activator the gold thing that goes to the wastegate flap? when i took the bar off the flap the bar went back in.
is that normal? or was it just stuck out ?
Old Apr 30, 2005 | 01:22 PM
chinto's Avatar
got every thing all back together still no boost.. so im thinkn its the solenoid / activator the gold thing..
any one have any thing else it might be? or how much a new solenoid would be?
Old Apr 30, 2005 | 02:21 PM
timzcat's Avatar
There is a spring in the actuator, you can't move it easily. If you can move the actuator arm easily then it is no good.
Old Apr 30, 2005 | 03:35 PM
chinto's Avatar
ok the waste gate part thats all rusted and attaches to the manifold moves easy. the gold part the acuator has spring to it kinda hard to move used lock grip plyers to put it back to gether..
Old Apr 30, 2005 | 04:12 PM
timzcat's Avatar
Okay that's normal. Did you try moving the rod and putting your finger over the pot to see if it holds? Have you tried driving it withthe vacuum hose off?
