Ferrea or Supertech valves?
Old May 1, 2005 | 09:53 AM
Derek888's Avatar
I am going to get the head built so I need some opinions as to which one you think will be better? I will be getting the 1mm over sized valves.
Old May 1, 2005 | 10:55 AM
11secEVO7's Avatar
I would go Ferrea...
dont have a clue about the difference...
but most of the high powered evos use it...like turbotrix.
thats a good enough reason for me
Old May 1, 2005 | 11:02 AM
Evo_doer's Avatar
I have used Ferrea in many other applications. They manufacture high quality cylinder head components. A very good choice indeed
Old May 1, 2005 | 11:45 AM
badlooser's Avatar
I flowed the stock valves and the Ferrera valves the Ferrera flowed more cfm. I put in Ferrera...
Old May 1, 2005 | 11:52 AM
bigyellowevo's Avatar
Ferrea
Old May 1, 2005 | 01:33 PM
954DRGSR's Avatar
I had the option of going with either when I ported my head - I chose Ferrea.
Unless you are going to run a lot of (> 30 Psi) boost I would recommend not going 1mm over and sticking with stock size valves.
Who's porting your head?
Old May 1, 2005 | 02:43 PM
1.8t's Avatar
Ferrea is the shizzel
Old May 1, 2005 | 03:04 PM
11secEVO7's Avatar
why not to go over 30psi with 1mm oversized?
doesnt turbotrix use ferrea oversized an they are over 30psi
Old May 1, 2005 | 03:11 PM
Evo_doer's Avatar
Yes this is true. I would like to hear why not to go over 30lbs boost also..
Old May 1, 2005 | 03:20 PM
KILTERMAN's Avatar
no what he is saying is that unless you are going over that (30 psi) you dont need oversized valves
Old May 1, 2005 | 03:24 PM
954DRGSR's Avatar
You're misunderstanding me. My recommendation is not to go with oversized valves unless you plan on running high boost. It is possible to get too large a port job for your application.
I'm running a ported head w/ a stockish turbo (10.5 backhousing) and to be honest I believe that porting has made my engine laggier down low. I'm running stock size valves and a street port which is not that aggresive compared to some. The restriction in my setup has essentially become the turbo.
Exactly. I was told this by the company that ported my head. It would have only been marginally more expensive for me to go with oversized valves, so it was not a question of money, just what best fit my application. This company (Portflow) has been around for a while and are quite reputable. They did beautiful work on my head. For additional info on them see attached: http://www.portflow.com/frame.htm
Old May 1, 2005 | 05:38 PM
TurbotrixRacing's Avatar
We dont use ferrea valves. .. but they are 1mil oversized.. They are good valves though ....
Mark
Turbotrix
Old May 1, 2005 | 09:36 PM
Derek888's Avatar
Mark
Turbotrix
which valves do you guys use?
Old May 1, 2005 | 11:18 PM
KILTERMAN's Avatar
Mark
Turbotrix
also would like to know this
Old May 2, 2005 | 05:19 PM
Ahhh im not sure ..to tell you the truth .. i think they are SI valves ..thats why i didnt mention it.. I just know they arent ferrara
mark
turbotrix
