Alky Kit
Old May 2, 2005 | 02:44 PM
03BREvo8's Avatar
Alky Kit
Just installed My SMC Alky kit today .. took a lil while ,bout 4 hrs.. but deff smooth install... You can hear the pump turn on as soon as you turn the key... and the ARM Light comes on... I have it set to 20 psi.. so once i hit that the SPRAY light comes on and will continue to and increase the spray vol and pressure all the way up till 26 psi... Im using 4 lt of 91% iso alc, and half gal of distilled water.. the other 4lt i dummped in to the rest of the half gallon and have it held steady in the trunk just incase i run low.. There is also a LOW light on the controll unit that tells you when you have 1/3 or less of a tank left... well nough for now.. ill let you know what if feels like when i have the need for speed..
Old May 2, 2005 | 03:29 PM
GOKOU's Avatar
Nice! I'm also looking into the alky kit as a possible mod in the future. Are you running it with stock head studs? If so please let me know how it goes cuz I'm debating whether to change head studs.
Old May 2, 2005 | 03:34 PM
FlyNavy's Avatar
Common advice is change them if at all possible unless you don't plan to boost past 21 or so. It would be sad to only run 21 though with all that safe power on the table with these kits. I think studs are a worthwhile mod regardless.
Old May 2, 2005 | 05:38 PM
03BREvo8's Avatar
havent changed them yet...
