Limits of stock valvetrain
Old May 2, 2005 | 05:05 PM
use2vtec's Avatar
I plan on taking my BR Stage 3 to the dragstrip Friday night. I feel confident that I will trap over 110 but less than 115. My question is with the 272s in there can I safely leave my car in fourth gear instead of shifting to fifth gear at 110 in the 1/4? What is the maximum I can take my car to on the stock valvetrain. I did some testing on a "priveate road" and every time I was at 7k RPMs in fourth gear before the 1/4 mile. So should I shift to fifth and lose some time or leave it in fourth?
-Leonard
Old May 2, 2005 | 05:10 PM
Az3ar's Avatar
-Leonard
with your mods 4th gear will be more than enough to finish your QM run.. dont put into 5th gear until you hit 120MPH or so (which you wont on your mods)... you are safe up to 7800RPM on stock head and bottom end..
good luck
Old May 2, 2005 | 05:41 PM
03BREvo8's Avatar
Hmmm you have the stock ecu no flash? with mine 3rd gear hits 110.. rev limit is now around 8800.... Havent had a prob at the track or any other time...
Old May 2, 2005 | 05:42 PM
03BREvo8's Avatar
even in stock form you should be able to hit 120 in 4th..
Old May 2, 2005 | 05:52 PM
use2vtec's Avatar
I have the BR Stage 3 flash from Dynoflash. I was just curious because around 110 im right at redline in fourth gear. i have never taken it in the red before and I wanted to post up before doing so.
Old May 2, 2005 | 05:55 PM
03BREvo8's Avatar
With al's flash it should have eliminated the stock fuel cut and raised the rev limiter... PM al to ask him first.. But im pretty sure..
Old May 2, 2005 | 07:47 PM
VTEC Killer's Avatar
redline on the engine and redline on the tach are 2 different things. Stock valvetrain will take up to 8,000. Just dont start banging it off the limiter , if anything right as your hitting rev limiter about to cross the line just depress the clutch, rather then shifting 5th for no reason
