br front mount problems
Old May 4, 2005 | 03:16 PM
AirNKAir5's Avatar
i just installed the buschur front mount and the lower i/c pipping and now i have buzzing noise whenever i hit boost (not sure if that is normal) and when i hit around 18 lbs, my car feels like it hits a fuel cut........
anyone have an idea of what might be causing this?????
the only thing i think it could be is the fact we have a boost source going from my upper i/c piping to the boost controller which was the same line that was attached to the stock lower i/c piping. I just haven't moved it to the bov line yet.....could this be a factor????????
Old May 4, 2005 | 03:21 PM
Derek Baker's Avatar
you need to check the lower intercooler piping. I believe that is where your leak is at. you need to drop the starter and take off the wastegate actuator (the gold thing on the turbo). when you install the lower intercooler pipe you need to make sure that you have the new gasket on their and tighten down the bolts evenly or else you will warp the flange.
I hope this helps you.
Derek
P.S. here is another link for you too.
https://www.evolutionm.net/forums/sh...cooler+install
Old May 5, 2005 | 11:41 AM
Did you fix the problem ???
Old May 5, 2005 | 12:17 PM
AirNKAir5's Avatar
ya, thx for the help.....the lower i/c piping clamp was too big and therefore didn't seal completely. i did take ur advice and go back and tighten the piping that connects to turbo and found it wasn't completely tight either, so thanx on that part.
